lc-1 wideband wire obd1 with neptune
Old 11-14-2014, 05:04 PM
gabrielsousa's Avatar
Default lc-1 wideband wire obd1 with neptune
i have same doubts about where to wire the lc-1 ground
where can i wire the ground ?
Old 11-15-2014, 01:07 PM
I'm Huge In Japan
VegasInvasion's Avatar
Default Re: lc-1 wideband wire obd1 with neptune
I use A23 for all the grounds, and A25 for power. They're right next to each other and it's switched, can't go wrong.
The brown wideband wire works better on D14 for me. But you're defeating the benefit of the LC1 if you're not using direct serial logging with Neptune.
Old 11-15-2014, 01:10 PM
D14 is limited to 3.8v .
what are the benefits of direct serial logging ?
Old 11-15-2014, 01:23 PM
and the BLACK ( calibration ) on A23 too ?
Old 11-28-2014, 06:00 AM
old connections
A25 -> RED
D10 -> BROWN
D22 -> BLUE and WHITE
A23 -> BLACK
LC-1 offset is -0.18
now my connections
A25 -> RED
D10 -> BROWN
D22 -> WHITE
A23 -> BLUE and BLACK
LC-1 offset is ZERO :D
Old 11-28-2014, 07:08 PM
I'm Huge In Japan
I would suggest using the same node for all grounds to avoid interference.
There is virtually no reason to ever need an AFR leaner than 3.8v, so unless you're doing a hypermileage tune, use D14.
Old 11-29-2014, 10:33 AM
thanks a lot.
i have a old firemware, if i upate the LC-1 firmware do i need to recalibrate ?
Old 01-06-2015, 07:48 AM
i change the LC-1 ground from D22 to A23 ,
and now shows less 2.0 AFR (ex. when was 15.0 is now 17.0)
but i if i change back the ground from A23 to D22
i have back my old AFR
when we change the ground do we need to calibrate again ?
i have more 30% fuel comparing to sotck p30, and a 70% duty cycle, i think the 2.0 less AFR isnt right
Old 01-07-2015, 04:41 AM
LTCxD2B's Avatar
The ground should be at the chassis not an Ecu wire
Old 01-07-2015, 04:45 AM
like this
Old 01-07-2015, 06:03 AM
LTCxD2B's Avatar
Yes
Old 01-07-2015, 12:29 PM
i was reading the AFR on neptune and tunerview ,
i connected the LC-1 on pc and with LogWorks, and the AFR is the same when the ground in on A23/A24 and the same on D22 , theres no change in AFR independently the ground source i use
the strange thing is, with different ground sources changes the AFR value on D10 /D14 (neptune) , but not on LogWorks
so...
using the D22 ground i have the same AFR value on neptune that shows on LogWorks ,
using A23/A24 ground i have less 2.0 AFR on neptune that shows on LogWorks
Old 01-08-2015, 07:33 AM
i had a -0.18 offset with BLUE (heater ground) and WHITE (system ground) on D22
with the WHITE (system ground) on D22
i change only the BLUE (heater ground) to A23, and now i have the same on LogWorks with ZERO offset
A25 -> RED
D10 -> BROWN
D22 -> WHITE
now my LC-1 offset is ZERO :D
Old 05-06-2016, 10:59 AM
is the A26 ground better than A23 ground to connect the LC1 ground ?
Old 03-04-2017, 05:39 AM
Txdragon's Avatar
Since I am searching for some info and found this post particularly, I will update it since it has fallen into limbo.. Short answer is the voltage output of the sensor is referenced to the ground. If the device measuring the sensor is connected to a different ground, the voltage difference between the grounds can shift the sensor output voltage relative to the measuring device. Yes, you should recalibrate if you change grounds.
super civic
Honda Civic (2006 - 2015)
10-09-2008 07:48 AM
JDMlyfestyle
19
02-04-2005 07:51 PM
Hatch It
06-08-2004 07:33 AM
Trigun
04-18-2002 03:26 AM
Quick Reply: lc-1 wideband wire obd1 with neptune
