How to set up Hondata s300 w/ water/meth
Old 04-13-2009, 07:09 AM
fearthis4's Avatar
Default How to set up Hondata s300 w/ water/meth
I recently ordered Honda S300 and was wandering if there was any guide to setting up Hondata to control a water/meth injection set-up...
Old 04-13-2009, 06:17 PM
fearthis4's Avatar
Default Re: How to set up Hondata s300 w/ water/meth?
Any one know anything about using S300 in this application?
Old 04-13-2009, 09:03 PM
2.7(p/t)
sander's Avatar
PWM control, or just turning a pump on or off?
In either case, the answer is yes.
Old 04-14-2009, 05:53 AM
fearthis4's Avatar
awesome...
Yes, turning the pump on and off, and failsafe wiring.... I'm still waiting for it to come in the mail but I want to get an idea of how to wire everything.
Old 04-15-2009, 08:45 PM
fearthis4's Avatar
bump need this info...
Old 04-20-2009, 10:58 AM
fearthis4's Avatar
Bump.. need this info..
Old 04-20-2009, 12:56 PM
sitinduk's Avatar
You can download the SManager software from Hondata.
In the Parameters window there is a Nitrous/AUX 1 input/output that can be setup as Water/Alcohol Injection.
You'll have to wire it according to the input and output pins you select.
Old 04-21-2009, 07:59 AM
ralph11sec's Avatar
dont forget the relay!
Old 04-23-2009, 07:27 AM
fearthis4's Avatar
sitinduk
Thanks for the response man,
however how do you wire the level switch.. for fail safe..? Or how to I wire the switch to change tunes/switch on water/meth...?
I have an idea of how this needs to be hooked up, I was just wandering if anyone knows of a place I could get a diagram of hondata hooked up to a water/meth set up w/ the failsafe..etc
ralph11sec
Yep.. IK you don't want to run the system straight off of the computer..lol
a relay is def. needed.
Old 05-03-2009, 08:48 PM
fearthis4's Avatar
Ok since nobody had a place to find a already completed Diagram I threw this Diagram together..LMK what you guys think...
civic-r11
Engine Management and Tuning
04-12-2010 11:51 PM
integra123
02-23-2006 10:33 AM
Kwuaymaikrup
12-27-2003 01:00 PM
gitwidit
05-09-2003 10:18 AM
Silverbeast
04-17-2002 12:24 PM
Quick Reply: How to set up Hondata s300 w/ water/meth
