Hondata s300 and rc750s fueling issue
Old 02-02-2016, 05:45 PM
RACEPAK's Avatar
Default Hondata s300 and rc750s fueling issue
hello everyone
i am having some trouble with a car i'm tuning with a s300 v3 and rc750's.
while i am using the hondata supplied offsets for the rc750's, i cant get the car to have normal idle afrs until i put -90 at the overall fuel trim tab, anything lower then -90 give me afrs of 13.0-12.0
when using crome/neptune offsets i can get normal afrs (13.7-15) with -30 overall FT.
any idea on how to solve this?
all my tests were in open loop. and everything in the options is disabled, this car was running mint with crome,
thanks
Old 02-02-2016, 07:40 PM
motoxxxman's Avatar
Default Re: Hondata s300 and rc750s fueling issue
Can you upload the current map? I'll take a look at it
Old 02-03-2016, 02:36 PM
RACEPAK's Avatar
yes sir
thanks
https://www.hondata.com/forum/download/file.php?id=8253
Old 02-03-2016, 05:12 PM
motoxxxman's Avatar
I'm looking at the map right now. what engine is this? and what did you use for a base map when you created this map?
Old 02-04-2016, 06:07 AM
Masterl1nk's Avatar
Do you have an aftermarket fuel pressure regulator? Which fuel pump are you running?
Maybe you need to set a higher value when you scaling injectors (like 800cc)
Old 02-08-2016, 10:20 AM
RACEPAK's Avatar
hi, thanks, its a D16Z6, i used the p28 map,
the car was running on crome and made 370whp on a mustang dyno with my last tune, before the hondata swap, we wanted to "upgrade"
thanks
Old 02-08-2016, 10:22 AM
RACEPAK's Avatar
thanks,
hello
i'm using a genuine walbro 255lph and a holly bolt on regulator,
about the scaling, i find it odd to have the need to "change" the injector size for it to work, i never had this issue on neptune ectune or crome,
thannks
Founder
K Series
01-30-2014 11:20 AM
MadVTI
Engine Management and Tuning
01-31-2009 10:59 PM
turbosi03
05-21-2003 06:00 PM
Quick Reply: Hondata s300 and rc750s fueling issue
