Honda Accord 2001 intermittent idle chug leads to p1381
Idle at 750 RPMs warm intermittent chug down every 5 seconds or so turn AC on and chug gets worse and more frequent and throws it into p1381 3000 RPM rev limit check engine light on.... i Clear code and raise idle at throttle cable wheel to 1000 rpms... everything runs perfect no p1381 no chug no check engine light but when I turn AC on idle lowers chug starts p1381 rev limit same thing..... 1500 RPM everything runs perfect even with the AC on but idle is too high for safe shifting auto trans ..... Alt checks out good .... thank you thank you very much
Jack jaxz
03-30-2016 04:35 PM
mwb928
08-14-2015 10:55 PM
TylerW
08-07-2005 01:31 PM
