GSR swap obd1 code4
GSR swap obd1 code4
Hi
I have ek hatch with 98 gsr swap and it throw a cell light
code 4
Everything seems fine but I can't rev up more than 5k rpm
It will shake so I have to rev down, then no shake
friend of mine said replace the dizzy will fix
Is that true?
code 4
Is that true?
Re: GSR swap obd1 code4
try using the search function. look up what code 4 stands for. that will answer your question.
p.s. the crank position sensor is located inside the distributor.
crex23
12
08-17-2005 03:24 PM
