Cant connect to com port... Crome
Ok i just got my ecu in today put it in and connected the 4 pin header and connected the cord to the usb blah blah. well i hooked it all up and says incorrect com port.. so i went to device manager and saw nothing about com port/ltp or something. So right when i plug the usb cable into my laptop a install hardware screen pops up. Sooo what do i do from here? i got 4 usb ports on my laptop and tryed up to com port 6 on the freelog and not of them worked. when i search for the com ports in the device manager its doesnt have them. has usb bus controllers is it? when i connect the usb cable ?Other Devices pops up in the device manager.. so what do i need to do? if i only got 4 usb ports it shouldnt go higher than comp port 4 right? lol sorry for the long random questions i just cant find out what to do
Sorry for the pics my camera sucks and its dark outside lol
for alittle more info if it helps..
using crome free and freelog.. can i still be able to log even though i got the free crome version?
Alright after looking into it a bit further last night i came across that i needed to install a specific usb driver for this. so i did so and still cant connect to the ECU through RTP on crome?? it connects to the port and get connect but cant connect to ecu for RTP. do i need crome pro for this? anyway i can pull up the data from my ecu without logging through crome? I tryed freelog and cant get any of it working.. rpms dont work mph and bat volt is way off and 75% of the things dont work in live data. does it matter which way the plug is plugged into the 4 pin header in the ecu? dont know if that would make a difference
Heres some pics
Heres some pics
I was just wondering if i can open up the base map thats on the ecu already and tune off that one? i dont really wanna start from scratch when this one is just alittle off of my liking.. when i try to goto plugins i cant add it because i dont have a rom opened
few pics
few pics
1. Open the co-existing binary you want to tune on.
2. Add the plug-ins required to datalog.
3. Make sure j12 is removed from your ecu, if not remove it using a small pair of snippers.
4. Try datalogging & follow the guide on http://www.moates.net/zips/crome/Tun...ME%20v1.03.pdf
HondaKing90
Audio / Security / Video
08-01-2010 04:20 AM
AlphaQup
11-07-2006 09:05 PM
Ls_dx
07-20-2006 08:52 AM
revhi
02-16-2006 01:16 PM
