My AC is not cold enough.
Old 07-09-2010, 01:58 PM
///EJ6POWER's Avatar
Icon6 My AC is not cold enough.
Ok well i bought two cans of AC Recharger 134a from walmart. i put 20oz. of it on my car and the max is 22oz. how can i make it colder! the AC is not super cold like other cars>?
Old 07-14-2010, 01:50 PM
psv4878's Avatar
Default Re: My AC is not cold enough.
maybe your expansion valve is bad. or your compressor
Old 07-17-2010, 09:10 PM
OMGRHD's Avatar
If you add too much refridgerant it will not work properly either. The only proper way to fix it is to recover the refridgerant from the system. Then pull the system into a strong vacuum. Then you can add your proper amount of refridgerant. Your best bet will probably be to go to a mechanics shop. The shop I work at charges about $100 to recharge your ac. If you add refridgerant to a completely empty system you will have air in it. This reduces the performance of your ac. I hope this helps.
Kyle
Old 07-19-2010, 10:09 PM
hey i noticed there is a chemical, i think its water coming out of the ac pipe line. would that be considered a leak? is that why it might be affecting the ac system?
Old 07-20-2010, 06:59 AM
MrDomino's Avatar
How the hell does this belong in the engine management and tuning section? Learn to read.
MyWhiteEJ6
08-16-2013 10:34 AM
CivicSD
08-20-2007 08:40 AM
vietnogi
05-24-2005 08:01 AM
Quick Reply: My AC is not cold enough.
