97 civic hx o2 sensor issues. help!
Old 12-29-2014, 10:56 PM
1997civichx's Avatar
Default 97 civic hx o2 sensor issues. help!
I don't know much, but I am baffled. I have a pretty much stock 1997 civic hx with a 5 speed, the only aftermarket items are a header, and cold air intake. The cel was on and the code said slow response from the o2 sensor and it ran terrible. So I unplugged it and it ran fine besides terrible gas milage and the cel on. So I put an o2 sensor defouler in both of the o2 sensors and it still ran bad, it sputtered bad at about 2500 rpm. I just bought an o2 sensor off of eBay and the wires on it were about 6 inches to short, so I cut the sensors and soldered 6 inches to the new sensor. The cel turned off and it drove fine through town but at about 60mph in 5th gear it would hesitate and bog and then it would go back to normal for a minute and then do it again. I would like to find a solution to this issue other than going back to stock. So I am stumped. Any help would be greatly appriciated.
thanks in advance.
Last edited by 1997civichx; 12-29-2014 at 10:59 PM. Reason: clicked submit on accident.
Old 12-30-2014, 10:28 AM
spAdam's Avatar
Default Re: 97 civic hx o2 sensor issues. help!
What did you put a non fouler on both sensors? You need to read up on what you're trying to accomplish.
The car should be absolutely dumping fuel.
Old 12-30-2014, 11:51 AM
I did put non fouler on both sensors.
Old 12-30-2014, 01:37 PM
spAdam's Avatar
Oh, because that's exactly what you said you did :
Anywho, the front sensor must be an LAF sensor, not the typical four wire heated O2S. I would recommend using an OEM or brown-box equivalent here, definitely not something that needs to be spliced in... the ecu tends to be pretty picky about them. The HX originally came with a close coupled cat/manifold combo a la DX/LX/CX, so you may have a hard time keeping it happy with the header on there, no matter what you do.
Start with the sensor and report back though, your bogey is most likely in that general area.
d's slow eg
05-05-2010 10:28 PM
turbo gli
06-06-2009 12:29 PM
importdreamer
05-26-2007 06:58 PM
longhair77
06-23-2006 11:00 AM
coldfiremx
08-17-2002 11:31 AM
Quick Reply: 97 civic hx o2 sensor issues. help!
