1.5 VTEC tuning - Honda-Tech
1.5 VTEC tuning
Old 03-09-2009, 12:39 PM   #1
New User
Default 1.5 VTEC tuning
Hi, i am new to the honda scene, so please try to understand if i ask some "stupid" questions!
First off, i am from the UK, and have an EK (97) Civic Ls (1.5 Vtec, 114bhp)
Now, i understand that this is not as desirable as the B16 line of engines, but was wondering if there was anything i could do to make it a bit nippier, and to especially feel the transition onto VTEC stronger, as there is no KICK there at the moment.
I think the engine code i have is D15? Is it possible to fit a performance cam designed for say, a D16 engine?
Any help is really appreciated!
Dan_GPR is offline   Reply With Quote
Old 03-09-2009, 12:53 PM   #2
phaphon's Avatar
Default Re: 1.5 VTEC tuning
they should have cams for a 1.5 and yes i believe it would make it feel alot stronger plus intake header and exhuast would help
phaphon is offline   Reply With Quote
Old 03-09-2009, 04:49 PM   #3
kicked25th's Avatar
A lot can be done with that motor.
kicked25th is offline   Reply With Quote
Old 03-09-2009, 08:06 PM   #4
THC07's Avatar
a lot?
when you have a single slam like the d15b there is NOT much you can do and stay NA.
for the money you would spend on intake, header, exhaust is not worth it. your butt dyno might feel it, but you would not be getting **** for power after the money you spent. Forced induction is your best bet. maybe somthing cheap like a dry n2o kit, or spend a little more and get a turbo. intake, header, exhaust on a d15b is just about pointless.
THC07 is offline   Reply With Quote
Old 03-11-2009, 07:02 PM   #5
kicked25th's Avatar
um there is a LOT you can do actually. almost everything you can do to a dual cam. the power might not be there but the parts are.
But i agree that FI is where the real power lies.
Old 03-13-2009, 07:26 AM   #6
THC07's Avatar
sure you can do all that, but why? you will not get any power. sorry but putting money into an NA Dseries is just dumb. unless you spend an assload and get some serious compression and a few thousand dollars later you will will be able to bark secound gear.
FI is the only way, imo
Old 03-13-2009, 09:22 AM   #7
unusual71's Avatar
no replacement for displacement
get something bigger if at all possible
unusual71 is offline   Reply With Quote
Understanding Chipped ECU's KingDakota12 Honda Civic / Del Sol (1992 - 2000) 50 04-26-2011 04:28 PM
D16 manifold on a D15 engine smirnofff Honda Civic / Del Sol (1992 - 2000) 11 06-21-2010 12:29 PM
d15b obd2 swap help adriel_wood Honda Civic / Del Sol (1992 - 2000) 2 05-12-2010 08:01 PM
obd2 d15b swap info zenon8890 Honda Civic / Del Sol (1992 - 2000) 1 11-24-2008 04:00 PM
My VTEC is not kicking in Mr. Fuji Honda Civic / Del Sol (1992 - 2000) 44 03-07-2007 10:14 AM
Tags
15, 1996, build, civic, d15b, ecu, florida, honda, list, make, single, slam, stronger, tuning, vtec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
