RSMachine 84.5mm B20 piston rings part number?
Old 02-28-2017, 09:02 PM
kccord's Avatar
Default RSMachine 84.5mm B20 piston rings part number?
Does anybody know the NPR piston ring part number for B20 rsmachine 84.5mm pistons? Bought a set of those pistons and it didn't come with rings. Seller doesn't know and RSmachine didn't get back to me after calling them and emailing them last week.
What makes it hard is that listed part number on NPR catalog is SWH30437ZZ(-2) which describes the thickness of; Top ring:1.2mm Second ring:1.2mm Oil ring: 2.8mm Bore: 84.5mm
That will not fit the rsmachine pistons as it requires the top ring thickness of 1.0mm. I must say I am beginning to regret buying these pistons because of the service, should of went with YCP's.
TIA.
Old 02-28-2017, 09:09 PM
kccord's Avatar
Default Re: RSMachine 84.5mm B20 piston rings part number?
Just to show I did my research, I found these rings to be plausible but fitment cannot confirmed as they don't specify the ring depth;
Hastings: SC8513-020
CP-Carillo: CPN-3327
Either set of those rings will cost me $200 delivered to Australia which is rather expensive...
Old 03-01-2017, 09:51 AM
Hysterically Calm
TomCat39's Avatar
If you have the dimensions of the ring lands of the pistons, can you not provide that information to Hastings or CP-Carillo and let them advise you?
Old 04-06-2017, 02:37 AM
trickeng's Avatar
Call Jesse @ JapanRacingProducts (951)453-1012. He is the importer for Nippon Racing pistons and most likely knows where they get there pistons and the correct rings.
kebroz
Honda CR-V & Element
09-18-2015 07:22 AM
ef9_b16a1
11-06-2007 06:34 PM
speedfanatic88
12-08-2006 02:41 AM
blackhatchb20
07-02-2006 07:01 AM
LSVTECoupe
02-06-2004 06:12 PM
Quick Reply: RSMachine 84.5mm B20 piston rings part number?
