Gsr block - Honda-Tech
Gsr block
Old 02-05-2017, 10:09 AM   #1
Default Gsr block
it may be a stupid an question but I just want to know
I got a bare gsr block my question is can I swap everything from the B20 to the gsr not the crank or piston ?
Jcb20v is offline   Reply With Quote
Old 02-06-2017, 09:51 AM   #2
Man U FTW
Schister66's Avatar
Default Re: Gsr block
You probably want to use the crank - GSR has an 87.2mm stroke whereas the LS/B20 crank is an 89mm.
Which pieces specifically were you looking to use? Obviously the pistons wont work (as you know), but the rest is the same as any LS block
Schister66 is offline   Reply With Quote
Old 02-06-2017, 10:12 AM   #3
So i so I can use the B20 crank on the gsr block and everything else like oil pump and little things like that ?
Old 02-08-2017, 07:34 AM   #4
Just depends on what you plan on doing with it. youll need a gsr oil pump and water pump to avoid cavitation.
eh2_Trav is offline   Reply With Quote
Old 02-08-2017, 09:13 AM   #5
Moderator
TheShodan's Avatar
And you remove the oil squirters in order to keep the from damaging piston skirts due to vibration. (Purchase a Golden Eagle Oil Squirter block kit).
Here's an example of when I did mine..
(God. I can't believe I did this almost 9 years ago.. Still have the car, too..)
Project EM1 - The Shodan goes NA
TheShodan is offline   Reply With Quote
gsr block question SLOENUF All Motor / Naturally Aspirated 10 02-24-2011 08:35 AM
FS: rs 2.0 B18c1 gsr jdm biker Northern California (Sales) 5 12-05-2006 07:29 PM
B20b head on GSR BLock!! WILL THIS WORK??? cowboybebop Tech / Misc 16 06-14-2005 05:31 PM
Question about B20/VTEC eREXion91 Honda CRX / EF Civic (1988 - 1991) 2 09-23-2004 06:02 PM
newb question tegasaurus Acura Integra 9 01-13-2004 07:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
