Gouge/crack in block??? - Honda-Tech
Old 01-25-2017, 10:51 AM   #1
Post Gouge/crack in block???
So i tore down my b18b to rebuild for boost. Everything meausred perfectly within tolerance, not even .001 deck warpage. I was surprised in how good of condition it was in for 170000 miles until i saw this. This is the outside wall of cylinder #1. Right by the water pump entrance. If you look close it looks like it may have cracked all the way down, or is that a casting imperfection down there. Anyways, is this block trash or can i fix this? [img]webkit-fake-url://e0a5e76f-258e-47c5-ac99-461a590c0433/imagejpeg[/img]
Hatchg is offline   Reply With Quote
Old 01-25-2017, 10:52 AM   #2
Default Re: Gouge/crack in block???
Also, the inside of the cylinder is fine, no cracks, scratches and measures perfectly
Old 01-25-2017, 11:58 AM   #3
Man U FTW
Schister66's Avatar
Thread moved to Engine Machining & Assembly forum. There is a redirect in place in the Integra forum for this thread
Schister66 is offline   Reply With Quote
Old 01-25-2017, 12:32 PM   #4
Quote:
are you asking me to move the thread or telling me you already did?
Old 01-25-2017, 08:55 PM   #5
Is the crack you have pictured vertical in the block, or is there also a horizontal crack that travels toward the #2 sleeve ???
Last edited by JRCivic1; 01-26-2017 at 09:12 PM. Reason: mis-spelling may cause confusion.
JRCivic1 is offline   Reply With Quote
Old 01-25-2017, 09:03 PM   #6
Quote:
Originally Posted by JRCivic1 View Post
Is the crank you have pictured vertical in the block, or is there also a horizontal crack that travels toward the #2 sleeve ???
What looks like a gouge is vertical along the outer sleeve of cylinder #1. Right by the water pump outlet. What looks like either crack or casting marks coming off of the gouge are traveling horizontally. And there is a small one that looks like either a crack or casting mark rigt at the bottom where the coolant jacket meets the outer sleeve. Since this is all on the outer part of the sleeve is it really that big of a deal? The inner cylinder wall is perfectly fine. Im only lookin to make around 300 whp
Old 01-25-2017, 09:10 PM   #7
Ill try to get a better picture of it tomorrow. I also found sand at the bottom of the coolant jackets. I bought the car with this motor and it ran incredibly well, especially for having 170,000 miles on it. The only reason i tore it apart is because I did a gsr swap with plans to build this motor for daily driven boost. The motor was showing no signs of damage, no leaking, no smoking, no overheating so im not sure what this could be from
Old 01-26-2017, 05:23 AM   #8
Man U FTW
Schister66's Avatar
Quote:
I already moved it and was just letting you know. You'll get better answers in this forum
Old 01-26-2017, 06:38 PM   #9
motoxxxman's Avatar
that definitely looks like a casting flaw. I'd say it's totally fine.
the "sand" in the coolant jacket is probably just corrosion buildup. I've seen it in many many motors when the coolant is never drained or flushed. also totally normal. just flush it out, good to go.
motoxxxman is offline   Reply With Quote
Old 01-27-2017, 12:05 AM   #10
even the "gouge" looking one? Thats a pretty gnarly casting flaw. Should i at least try to file down the sharp edges off it? Wouldn't those cause stress points?
Old 01-27-2017, 05:00 AM   #11
motoxxxman's Avatar
yeah, flaws like that happen sometimes. and no, it won't cause any stress points. you could file it down, but I don't think it would make any difference. It's just the aluminum that encases the steel cylinder. the aluminum part is just there to locate the steel sleeve. the steel sleeve is the structure for cylinder pressure.
Old 01-31-2017, 06:18 PM   #12
92_civic_eg's Avatar
you will be perfectly fine with that, dont worry
92_civic_eg is offline   Reply With Quote
Old 02-04-2017, 03:38 AM   #13
That happens when the block is removed from the casting mold. It's not uncommon to see.
Runnerdown is offline   Reply With Quote
Carbon fiber hood crack lolv8s Tech / Misc 6 05-09-2016 12:55 PM
The Beginning: 1995 EG Hatch Build. 56k BE AFRAID!! 95DC2GS-R Honda Civic / Del Sol (1992 - 2000) 21 01-19-2009 02:42 PM
Over torqued oil t in block and block cracked em1 Ziggy Forced Induction 55 05-12-2006 11:08 PM
spare Block cracked question brads94accord Honda Accord (1990 - 2002) 5 02-26-2006 07:53 PM
WTB im looking a a b18c5 block that has cracked sleves or needs boreing?? gulf imports For Sale 30 08-09-2003 11:00 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
