cam bearing 2nd opinion
Old 08-10-2015, 06:52 PM
ryanplayjoint's Avatar
Default cam bearing 2nd opinion
Was told the intake can bearing would be OK it has a small crack that does catch the finger nail. What do you think?
Old 08-11-2015, 01:19 PM
Hatch3d's Avatar
Default Re: cam bearing 2nd opinion
I'm no expert but if I were looking for any kind of internal hp gains I wouldn't trust it.
Old 08-11-2015, 01:27 PM
PyroProblem's Avatar
I'd double check the cam to journal clearance also. I dont know how media blasting machined surfaces could affect the mating surfaces of the cam caps clearance wise.
Old 08-11-2015, 05:54 PM
Moderator in Chief
Muckman's Avatar
Id run it personally.
Old 08-12-2015, 10:01 AM
2000FBPITR's Avatar
I really don't understand your Question... Are you asking what we think about the Journal? It looks fine. RUn your finger over it, if you don't feel indentations you're good..
Old 08-12-2015, 10:33 AM
There's is a very small crack forming at the edge of the hole. I had to zoom in to see it.
If your really concerned you could very very carefully blend out the crack in a downward only direction to remove it and keep it from spreading. But it is so small, I kinda think you would be ok as well. I'm no expert either.
Old 08-12-2015, 07:24 PM
92cxturbo's Avatar
I would think that crack will get worse with vibration. Kinda risky imo.
Old 08-13-2015, 02:42 AM
I'm brining it to a local machine shop for a port match today and I'll see what he thinks of the crack.
Old 08-13-2015, 09:32 AM
2000FBPITR's Avatar
You know what because of how the wording was augmented to the right I didn't see it. I see it now. It doesn't look too bad, however how and why is it cracking is more concerning. I have never saw that in my life.
Old 08-30-2015, 03:55 AM
H22egguy's Avatar
I personally don't see a crack... do you mean the journal or next to the cam cap hole? I noticed you mentioned hole. the journal looks fine. If there is a crack at the cam cap mount hole you should be fine just don't over tighten any bolts torque them to spec and be done with it.
Old 08-31-2015, 03:07 PM
Look right at about the 9 o clock position at the head bolt hole, but on the journal. Its very small.
Old 08-31-2015, 03:10 PM
Is it ok to media blast the machined mating surfaces of the cam caps like that? I would think it could affect the clearance in some way.
Old 09-09-2015, 07:37 AM
spAdam's Avatar
I'd be more worried about the fact that all of your machined mating/gasketing surfaces have been media blasted. That's not right.
DOHCturbo
07-04-2010 06:26 PM
xgtrp98x@aim.com
Honda S2000
10-12-2009 12:57 PM
Neukin
06-30-2006 02:57 AM
SL_RICK83
01-24-2006 02:12 PM
onePOINTsix
03-10-2004 08:08 AM
Quick Reply: cam bearing 2nd opinion
