Degree cams after short block build?
Hi guys.
I'm building up a high compression NA GSR. 12.5:1 pistons, forged rods and GSR crank. I've got an engine running already in the car with a complete Supertech valve train, including flat faced valves. I also have S2P1 cams that have been degreed. I'm planning on installing the built head onto the built engine.
The question is, do I have to degree the cams again for the new short block?
Any help on this would be appreciated. Plenty of info about degreeing cams, but couldn't find anything about my question.
Re: Degree cams after short block build?
I can't say I'm familiar with your setup, however, I am not sure how you could assume the blocks are going to be the same, unless they are the same/built the same. Then I don't think you would need to go through everything again.
I would think you would need to both clay and degree the cams if you move the head to a new block if the new block is built differently. Just seems like common sense to me.
That being said, I could be mistaken as I'm not a master by any means, what I've stated is just my initial thoughts on what you've provided.
Degreeing the cams is a necessary step if you do ANY of the following:
Change block
Deck block
Change cylinder head
Deck/mill cylinder head
Change head gasket
Change or remove timing belt... change or loosen tensioner
Cam change
Crankshaft change.
Align hone crank main journals or camshaft journals
Change block
Deck block
Change head gasket
Cam change
Crankshaft change.
Change block
Deck block
Change head gasket
Cam change
Crankshaft change.
Change block
Deck block
Change head gasket
Cam change
Crankshaft change.
Villain, my statement with regards to a change in timing belt or tensioner holds true with a handful of exceptions. IF you were to degree a set of cams on a fresh engine with a brand new timing belt, and you were to replace the timing belt sometime thereafter with the same BRAND timing belt WITHOUT loosening the tensioner... you would be correct in that it is unlikely that the relationship between the cams and crank would change... so equally likely that degreeing the cams would be un-necessary. However, if your timing belt replacement process includes replacing or adjusting the tensioner, then cam to crank phasing can be altered and degreeing should be checked for maximum power.
You are also correct in that the theory of belt stretch altering the cam settings has merit. The easiest way to test for this is to strap the car to a dyno and advance both cams ever so slightly (and equally) and see if the power increases.
16
12-22-2004 03:25 PM
