d16z6 weird rear main seal housing?
Old 10-01-2016, 05:02 PM
blitzinq's Avatar
Default d16z6 weird rear main seal housing?
I am refreshing a d16z6 engine before dropping it into my rt4wd wagon. I've been slowly replacing wear/tear items and made it to the rear main seal today. I pulled the housing off, started trying to remove the gasket, and noticed that something seems off. My rear main seal housing has a metal ring in the center, there was gasket material on both sides of it. I had ordered a brand new rear main seal from honda specific for the z6, and it also does not seem like quite the right one. Am I missing something?
In the pictures, the area in the center where you can see gasket material somewhat taken off is metal.
blitzinq is offline
Old 10-03-2016, 10:48 PM
Hysterically Calm
TomCat39's Avatar
Default Re: d16z6 weird rear main seal housing?
You received a solid answer in the other section you posted this question in.
For other's reference, the answer can be found in this thread:
https://honda-tech.com/forums/honda-...using-3286245/
TomCat39 is offline
blitzinq
10-02-2016 11:08 AM
zrs6v4
10-14-2009 09:52 AM
95streetciv
05-15-2008 07:23 AM
volkswagentuned
09-02-2006 06:41 PM
Quick Reply: d16z6 weird rear main seal housing?
