D16 p08 head surface control
Old 12-07-2016, 09:18 PM
G-power's Avatar
Default D16 p08 head surface control
Hi all, I give p08 head for prof surface , i added photo this good or bad .i need idea
Thank's
Old 12-08-2016, 05:49 AM
Hysterically Calm
TomCat39's Avatar
Default Re: D16 p08 head surface control
Take it to your machine shop and they can tell you what it needs.
Old 12-08-2016, 08:08 AM
G-power's Avatar
I give machine Shop they do this friend look full ,screen pls i See scratch i dont want again surface
My question This scratch's problem?
Thank you
Old 12-08-2016, 12:07 PM
Hysterically Calm
TomCat39's Avatar
Thank you
Oh I see, thank you for clarifying.
I would believe this would be warranty work by the machine shop if they created the scratches/grooves seen in the picture.
Old 12-08-2016, 06:29 PM
PyroProblem's Avatar
Another thousandth or 2 of an inch should clean that up.
If you line up your headgasket to the head, you'll probably see the "fire ring" of the HG contact the scratch. If this is the case, Id have them skim it again just to be safe. Its hardest working gasket inside your engine.
Old 12-08-2016, 08:29 PM
Hysterically Calm
TomCat39's Avatar
If you notice the straight line dashes, it's not from the gasket. It looks like there was a bur on the planing machine that left a perfectly straight line of dash scratches all the way up the head.
I just hope the machine shop doesn't try and deny it was their doing, but it's pretty plain that it was done with machine precision.
Old 12-08-2016, 09:34 PM
G-power's Avatar
Today im giong machine shop ,off Course they again do it
Re surface
Throwdown
11-25-2012 07:17 PM
integranator
02-19-2008 05:56 PM
RACEPAK
07-22-2007 07:08 AM
dohcgarage@714
02-04-2007 12:25 AM
fe519
03-17-2005 11:29 AM
Quick Reply: D16 p08 head surface control
