Block Sleeving and parts fabrication
Old 07-13-2013, 01:48 PM
  #51
Mach1n1st's Avatar
Default Re: Block Sleeving and parts fabrication
There is clearance between the flats
Old 07-19-2013, 07:34 AM
  #52
wreckeddc4's Avatar
You must be who did my block. I went through Chris at Xenocron. Turn around was great, the shipper I used did a crap job packaging it and caused some damage during shipping and it was fixed for no extra cost.
Not to mention the workmanship looks top notch.
Old 07-19-2013, 08:32 PM
  #53
Who is Mr Robot?
wantboost's Avatar
I always enjoy proper fabrication work, makes me miss working at the machine shop
I'm curious though, any issues with scavenging on the Subaru with the pump mounted that high? I know there isn't a lot of room to work with given the engine layout.
Old 07-20-2013, 09:20 AM
  #54
Mach1n1st's Avatar
Thanks man. I work very hard to produce a great product.
Old 07-20-2013, 09:23 AM
  #55
Mach1n1st's Avatar
No problems with the drysump system. it was a HUGE pain in the *** to go it though. Im in the middle of doing another subaru with just about the same setup now.
Old 07-20-2013, 01:55 PM
  #56
Who is Mr Robot?
wantboost's Avatar
Well if I ever decide to sleeve another b series block you're the first persob I'm going to
Your work is simply amazing
Old 07-23-2013, 09:10 PM
  #57
Mach1n1st's Avatar
Howard showing off his iPhone camera skills tonight while I slay more blocks.
Old 07-23-2013, 09:14 PM
  #58
AR Fab's Avatar
The B17 unicorn of CNY Performance.
Old 07-24-2013, 05:16 AM
  #59
tepid1's Avatar
What's with the gaps between the sleeves?
My machinist have them looking like one piece....
All different engine types, all the same results.
Old 07-24-2013, 07:03 AM
  #60
DaveF's Avatar
is that an s2k block with the piston sticking out of the deck ?
Old 07-24-2013, 07:35 AM
  #61
tepid1's Avatar
H23
Old 07-24-2013, 10:11 AM
  #62
Mach1n1st's Avatar
It is the chamfer that is still showing. Saves cutter inserts not taking more than needed off of the sleeve. The sleeves that are not chamfered on the flat edge look like this. There is veryyyy little gap on the ones that you are referring too. It's just a aesthetic thing I've never had any issues with leaving the small amount of chamfer on there.
Old 07-24-2013, 07:43 PM
  #63
AR Fab's Avatar
The installation of Darton sleeves has a specified clearance between the sleeves...as per Darton and other manufacturers. This is built into the recommended bore offset and the machined flat tolerances per blueprint. As the engineer for the Darton sleeves states, "this clearance is for the sealant used between the sleeves".
Old 07-28-2013, 08:12 AM
  #64
Zer0_SpeedWorks's Avatar
Great work!
Are these aebs sleeves?
Old 07-31-2013, 02:54 PM
  #65
Mach1n1st's Avatar
Making a large run of deck plates for bore/hone and ring gap.
Old 07-31-2013, 03:22 PM
  #66
riceburner700's Avatar
perfection right there
Old 08-01-2013, 02:40 PM
  #67
Mach1n1st's Avatar
Sfwd short block looking fresh!!!
Old 08-01-2013, 03:38 PM
  #68
torkh22a's Avatar
Old 08-09-2013, 08:29 AM
  #69
Xavo ef's Avatar
Some of my favorite sleeves hands down best bang for your $$$ holds 800+ whp and is not as expensive as a closed deck.. And saves me time on install/machining time.
How much are this one for a f20c (s2000) ?
Nice job !!!!
Old 08-12-2013, 11:45 AM
  #70
allblkcoup's Avatar
O-ringing a b series closed deck
can u post or inbox me ur contact imfo. im looking for a new sleev guy
Old 08-12-2013, 03:56 PM
  #71
Mach1n1st's Avatar
Pm'd sir
Old 08-13-2013, 12:03 AM
  #72
HT White Ops
SD_Lurker's Avatar
Is this RLZ?
Old 08-13-2013, 01:08 PM
  #73
Mach1n1st's Avatar
Nope guess again
Old 08-20-2013, 05:49 AM
  #74
2000CTRSi's Avatar
JHEngine?
Old 08-20-2013, 09:56 AM
  #75
SP GARAGE's Avatar
I got your message and will give you a call later this week
Quick Reply: Block Sleeving and parts fabrication
