b18b crank = b20b Crank??? - Honda-Tech
Old 02-09-2017, 05:36 AM   #1
Default b18b crank = b20b Crank???
I have a 97 ek hatch with a jdm b20 from hmo that is knocking. Possible rod knock. But not sure yet. Im looking for a b20 factory crank to replace mine in case i need to. the only ones i can find are brian crower and eagle cranks which cost 700 dollars. My question....Is the b18b crank the same? could i just get a b18b crank micropolished and throw it in my b20? and if so will those rods work too? Leaving me with just swapping my current pistons over to the b18 crank and rods. Also will my block need to be honed if i had a rod bearing fail? any help will be appreciated
Pvtjrob is offline   Reply With Quote
Old 02-09-2017, 07:09 AM   #2
civic-steve-94's Avatar
Default Re: b18b crank = b20b Crank???
Yes the b18b and b20 cranks are the same, but if you install it all clearances must be checked. If the tolerances on the mains is to tight then yes it will need to be line honed. If you indeed had a rod bearing spin the once again the rod will need to be checked and resized or replaced. My advice is pull the block and get it to a good machine shop and go from there.
civic-steve-94 is offline   Reply With Quote
F20b won't crank need help asap!! 97ludef20b Honda Prelude 3 06-22-2014 07:47 AM
b18c5. Ls crank swap dc4teg95 All Motor / Naturally Aspirated 29 04-11-2013 06:22 AM
b20 crank amios Hybrid / Engine Swaps 3 08-19-2009 02:56 PM
GSR crank with LS oil pump? Airific Acura Integra 1 11-01-2005 10:35 PM
B20 crank..... turbod92hatch Tech / Misc 3 03-09-2003 08:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
