Gsr block
Old 02-05-2017, 10:09 AM
Jcb20v's Avatar
Default Gsr block
it may be a stupid an question but I just want to know
I got a bare gsr block my question is can I swap everything from the B20 to the gsr not the crank or piston ?
Old 02-06-2017, 09:51 AM
Man U FTW
Schister66's Avatar
Default Re: Gsr block
You probably want to use the crank - GSR has an 87.2mm stroke whereas the LS/B20 crank is an 89mm.
Which pieces specifically were you looking to use? Obviously the pistons wont work (as you know), but the rest is the same as any LS block
Old 02-06-2017, 10:12 AM
Jcb20v's Avatar
So i so I can use the B20 crank on the gsr block and everything else like oil pump and little things like that ?
Old 02-08-2017, 07:34 AM
eh2_Trav's Avatar
Just depends on what you plan on doing with it. youll need a gsr oil pump and water pump to avoid cavitation.
Old 02-08-2017, 09:13 AM
Moderator
TheShodan's Avatar
And you remove the oil squirters in order to keep the from damaging piston skirts due to vibration. (Purchase a Golden Eagle Oil Squirter block kit).
Here's an example of when I did mine..
(God. I can't believe I did this almost 9 years ago.. Still have the car, too..)
https://honda-tech.com/forums/all-mo...es-na-2458563/
dem0nk1d
09-19-2006 06:02 PM
civicswap
03-19-2006 05:27 PM
H23vtecEG
10
01-22-2005 02:34 PM
JBBNJ609
11
11-11-2004 11:40 AM
fabshybrid
16
08-07-2004 09:27 PM
Quick Reply: Gsr block
