B18 trouble
B18 trouble
Hi well let me start off by saying I rebuilt my b18b1 did everything right finished everything and put it back together and it ran like crap pulled spark plugs and had oil covered in them did a compression test and it had 65 psi in each cylinder can I get some help?!! Thanks 😄
Re: B18 trouble
What was your piston to wall clearance? What was your ring gaps set to?
Usually when I have a low compression problem, I do a cylinder leakage test to see WHERE the compression is lost.
If all 4 cylinders have only 65 psi, you may have a camshaft timing problem.
Ferio Wdm Edition
Re: B18 trouble
Put a little bit of oil on the pistons and see if it leaks down. If it holds, its alright, if not, then thats your issue, but probably, its in the valves. Turn the head upside down and pour some oil and se if the oil leaks down in. When you do that, do it to the head and pistons at the same time and check it in like 5 minutes. Free and effective way to do it.. thats what i did!
Re: B18 trouble
You did check your ring gaps, right? Any had the PTW clearance checked and set by a machine shop?
Valve lash set correctly?
Ferio Wdm Edition
Re: B18 trouble
Mark where the levels are and check back tomorrow If everything is good. Did you get a fresh hone? Cyl 2 looks a bit off to me... If thats all good, then you need to redo timing. You made sure everything was lined up? Cyl 1 on TDC? cams lined up with the top head?
Ferio Wdm Edition
Re: B18 trouble
Did you clock the rings the right way? If its new rings on a non honed block, you wont get a good seal. Are the pistons good? Why did you rebuild it? Was you burning oil prior to building the motor, or was it running just fine? What did you add? Tell the details!!!!
Re: B18 trouble
Letting it seat still so far so good also honing the cylinders tomorrow and I rebuilt it because I bought it boosted with an integra pulled it out and all the ring lands was done
Re: B18 trouble
Bump so far taking out Pistons today and honing it and re going over everything new rings clocked th right way but I think you're right about it not sealing right without a fresh hone
Re: B18 trouble
Oil didn't leak at all still at same level on both the block and the head tdc was done with the head off lined it all up 100% put the head on and made sure tdc on head was perfect
Ferio Wdm Edition
Re: B18 trouble
So cyl 1 was at the very top of the stroke? And the little nick on the crank lines up with the mark on the oil pump housing? Im wondering if the head might have a crack in the spark plug holes. Only way oil can get in the spark plug holes if the spark plug gaskets are bad. Strange issue, you have man
