b16a2 plastigage results. what do we think.
Old 07-17-2015, 01:14 PM
the_insider's Avatar
Default b16a2 plastigage results. what do we think.
Going by the following pics. Would you say these are good results?
Fitted with new standard fitment acl bearings.
Old 07-17-2015, 01:19 PM
famous323's Avatar
Default Re: b16a2 plastigage results. what do we think.
did you clean the journals well? i say this because any oil left over can cause a false reading.
Old 07-17-2015, 01:29 PM
Yes. Cleaned with microfiber and torqued to 45lb with lube arp2000 bolts
Old 07-17-2015, 04:25 PM
PyroProblem's Avatar
Is it just me or does metric plastigauge look a lot bigger than american standard?
I'd say it looks to be just a hair less than 1.5 so I'd say it's right about 1.4mm .
Curious how big (diameter) your plastigauge is before you squish it? How much bigger than fishing line is it?
Old 07-17-2015, 04:32 PM
hardcore97's Avatar
should have used green not red
Old 07-17-2015, 05:12 PM
blackeg's Avatar
yeah i also use green for the bearing tolerances. isnt the red the next size larger making it harder to estimate...
Old 07-17-2015, 08:02 PM
1HGEJ2's Avatar
Dont use plastigauge..u should use plastigage in inch or mm..
Old 07-27-2015, 12:00 PM
theYBLEGAL's Avatar
I think you should have used green not red.
Old 07-28-2015, 05:38 AM
Pro-SeriesFab's Avatar
I would also suggest green as it is supposed to be more accurate under .003 clearance BUT I would also recommend using outside micrometers and a dial bore gauge if you plan on building your own engines.
The inherent subjectivity of Plastigage is no replacement for the +/-.0001 of micrometers and a bore gauge or inside micrometer. If you margin of error on plastigage is +/-.0005 up to .001 then it's potentially 30-50% error on your exact clearance.
Old 07-28-2015, 06:48 AM
efHondefender's Avatar
assuming that's measuring in thousandths, I would say 0.0013-0.0014" is a little tight on the rods.
that-guy
Welding / Fabrication
36
09-07-2012 04:23 AM
nemesis25
01-15-2010 10:56 AM
NA JDM GSR
10-16-2006 03:01 PM
MRturbo
05-25-2006 08:41 AM
UncleBen'sRacing
03-08-2003 10:34 PM
Quick Reply: b16a2 plastigage results. what do we think.
