f20b build
Old 12-16-2016, 09:48 PM
jdmeg6fan's Avatar
Default f20b build
hey guys been awhile since I was on here. getting back in to the scene. I have a f20b sitting in the garage with bad crank and rods spun a bearing a while back. I would like to put a h22,h23a, or f23 crank and rods considering there all 55m. my only concern is would any of these combos work with using stock f20b pistons. TIA
Old 12-29-2016, 09:51 PM
PyroProblem's Avatar
Default Re: f20b build
Youd need to compare the compression height of those pistons to make sure they wont stick out of the block. Then verify the block deck heights are the same. Then wristpin size, and if all that checks out, I think it would work as long as you keep the crank and rods matched together.
This is a question for the F and H guys...
jdm_rb20
17
03-06-2013 07:43 PM
prodragEG
06-08-2008 08:54 PM
JDMjdawg
07-15-2004 12:55 AM
genius
12-02-2002 10:16 AM
DAYUIZ
04-11-2002 02:52 PM
Quick Reply: f20b build
