Acl Race main bearing clearances b20b
Hi hope some one can help I have just installed std acl race bearings on my b20 build and the clearances on all 5 caps are a even 0.024 mm I no this is right on the limit on the spec of 0.024 to 0.038 new. just concerned if this may be too tight?
Re: Acl Race main bearing clearances b20b
you can mix oem's by 1 color difference, dont mix hx and regular the difference is too large. definitely run the acl's on your rods
