What crank pulley/Harmonic balancer are you running? - Honda-Tech
Old 07-13-2004, 05:48 PM   #1
hondaguyef's Avatar
Default What crank pulley/Harmonic balancer are you running?
I want to see what everyone is running. If you select one please reply and post the setup or just simply if your car is turbo/supercharged or all motor. Also if you have positive or negative feedback about one of the pullies listed please post. Thanks
Phil
hondaguyef is offline   Reply With Quote
Old 07-13-2004, 05:50 PM   #2
PM-Performance's Avatar
Default Re: What crank pulley/Harmonic balancer are you running? (hondaguyef)
stock ITR here
PM-Performance is offline   Reply With Quote
Old 07-13-2004, 05:55 PM   #3
Jokerluv's Avatar
stock D series
Jokerluv is offline   Reply With Quote
Old 07-13-2004, 05:57 PM   #4
SpeedDreamz.com's Avatar
Default Re: (Jokerluv)
unorthodox and oe
SpeedDreamz.com is offline   Reply With Quote
Old 07-13-2004, 06:15 PM   #5
jdkindle's Avatar
stock K series
jdkindle is offline   Reply With Quote
Old 07-13-2004, 06:17 PM   #6
SIckH22Atch's Avatar
Default Re: (jdkindle)
UR... makes for quick revving
SIckH22Atch is offline   Reply With Quote
Old 07-13-2004, 06:22 PM   #7
EGkid's Avatar
Default Re: (SIckH22Atch)
oem gsr
EGkid is offline   Reply With Quote
Old 07-13-2004, 06:24 PM   #8
Quote:
Originally Posted by Jokerluv
stock D series
MooreBoost is offline   Reply With Quote
Old 07-13-2004, 06:40 PM   #9
Blown90hatcH's Avatar
Default Re: (tegunderpressure)
N1 pulley killed my oil pump after 1k miles. Now I am stock ITR oil pump with Fluidampr crank pulley.
Blown90hatcH is offline   Reply With Quote
Old 07-13-2004, 06:41 PM   #10
Rod.'s Avatar
oem LS
Rod. is offline   Reply With Quote
Old 07-13-2004, 06:41 PM   #11
E-Town4229's Avatar
CTR here. works well. havent noticed any problems yet. single pulley is key with such a tight space.
-Roger
E-Town4229 is offline   Reply With Quote
Old 07-13-2004, 06:45 PM   #12
Robb's Avatar
Default Re: (E-Town4229)
stock H22 pulley.
Robb is offline   Reply With Quote
Old 07-13-2004, 06:49 PM   #13
wpgcivic's Avatar
stock b16
wpgcivic is offline   Reply With Quote
Old 07-13-2004, 07:05 PM   #14
GSRswapandslow.
Guest
Posts: n/a
stock ITR
Old 07-13-2004, 07:09 PM   #15
opto_isolator's Avatar
Haha - no Dick Hickman listed? Comon now, his crank pulley is only like freaking 4 ozs or something.....
opto_isolator is offline   Reply With Quote
Old 07-13-2004, 07:12 PM   #16
jdmoutlaw's Avatar
Default Re: (opto_isolator)
Stock b16, have yet to have a need for anything more . lol
jdmoutlaw is offline   Reply With Quote
Old 07-13-2004, 07:57 PM   #17
doublej's Avatar
You IM me for my experiences since I advertise Fluidampr in my sig. Here go's.
The Fluidampr test was conducted at my shop. I freely admit to understanding little on their computer test screens. But we dyno'd more than a dozen prototypes both sweep runs and at various static rpms. It's quite a process to map the harmonics. Fred Rowland is a very smart man, an enthusiest, and hands-on knowlege about their products. I enjoyed and learned alot during the test. I believe in the company and support the product.
My "personal" conclusions, based on this test and prior experience in other forms of four cylinder auto racing, were the Honda engine does need some sort of damper. And tailored to the engines use. The harmonics of a race engine are not the same as a stock street engine. That is the point. The oil pump and the bearings will thank you.
Can you get by with stock or no damper? Others obviously have but my luck doesn't run that way. More important, you have alot of money invested in your engines and want them to last a reasonable time. A little more than $300 is cheap compared to fixing/replacing an engine.
And you can open the hood and see it! Can't do that with piston.
Howard Anderson, AR Fabrication, uses the Fluidampr Racedampr. Jason Hunt and Brian Ballard (on it's way) use the Fluidampr Streetdampr. Both SFI approved. The Streetdampr fits their CRX's without mods to the traction bar. I think Z10 has a modified bar for the Racedampr and ATI damper.
Jim
doublej is offline   Reply With Quote
Old 07-13-2004, 08:02 PM   #18
Jared's Avatar
I use OE since I've seen two oil pumps destroyed with N1 and Unorthodox.
Jared is offline   Reply With Quote
Old 07-13-2004, 08:45 PM   #19
* B A N N E D *
Default Re: What crank pulley/Harmonic balancer are you running? (Jared)
dh-racing.com
chris_m is offline   Reply With Quote
Old 07-13-2004, 09:16 PM   #20
bomber's Avatar
Default Re: What crank pulley/Harmonic balancer are you running? (alld16a)
Since someone brought this subject up...I have been meaning to ask about the SFI 18.1 spec harmonic balancer rule for cars running 10.99 or faster.
I know the OEM one isn't supposed to be legal, but it seems everyone at the track is still using the stock one.
So, is this some rule that doesnt get enforced or what? If it is something I need to worry about, who makes a H22A balancer?
bomber is offline   Reply With Quote
Old 07-13-2004, 09:17 PM   #21
* B A N N E D *
Default Re: What crank pulley/Harmonic balancer are you running? (bomber)
I think it's just one of those rules that isnt really paid attention too.
Old 07-13-2004, 10:02 PM   #22
OaksRacing's Avatar
ATI steel damper with Peterson's Dry sump system - This was the prototype for their H22 Dry Sump System.
Check it out - http://www.cardomain.com/id/oaksracing
Steve Sr.
OaksRacing is offline   Reply With Quote
Old 07-13-2004, 10:12 PM   #23
Better than steak
Arturbo's Avatar
Default Re: What crank pulley/Harmonic balancer are you running? (doublej)
Jim
Jim Justice is my hero. I too run the Fluidamper and thanks for all the research you did with it jim. I have so much respect for you..
art
Arturbo is offline   Reply With Quote
Old 07-14-2004, 09:29 PM   #24
Tbone's Avatar
I run the ATI steel unit.
Jim Justice also Does all my machine work
And yes z10 can make a mod kit for the units to clear traction bars in crx's,(thanks to me )
Tbone is offline   Reply With Quote
Old 07-15-2004, 10:56 AM   #25
turbo*s2k's Avatar
Default Re: What crank pulley/Harmonic balancer are you running? (Tbone)
Stock b16a2 here!
turbo*s2k is offline   Reply With Quote
Post your Boost by Gear setup mikkey1 Forced Induction 13 06-26-2011 01:59 PM
i will buy a 88-92 crx tegra33 Honda CRX / EF Civic (1988 - 1991) 8 02-19-2005 08:19 PM
b16 hatches post your times here hybridEj6 Drag Racing 4 10-12-2003 03:00 PM
Anyone have a Civic Si running 11's? 9krpm Forced Induction 48 03-10-2003 10:25 PM
What kind of cams are you guys running in your B18/B20 non-VTECs? Jared Tech / Misc 7 07-04-2002 11:40 AM
Tags
ar, arizona, ati, b16a2, balancer, cardomain, crank, damper, engine, fabrication, failure, fluid, honda, jared, pulley, race
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
