What axles do i use for a h22a4 in ek
I have currently 90-93 Da axles seem to be leaking on passenger side
Or just buy gator axles or insane shafts swap axles
Re: What axles do i use for a h22a4 in ek
A H series transmission needs either an Accord or Prelude inner joint to fully clip in on the passenger side axle. Or you will be just sliding the axle in and out and destroying your transmission in the process when driving and turning.
I would go with a 88-89 Integra passenger side axle with Accord or Prelude inner joint 1/2" shorter then 90-93 Integra.
So buy 2 axles at $50 each NAPA best aftermarket casting and piece the Accord and Integra together. Or call up any axle Co. Give them the specs and have one made for under $200.
Could be just transmission oil coming out when shaft comes out? Or Axle boot torn or will have grease coming all the way around it out as if the clip will not be holding it enough.
-Happy Motoring!
-Happy Motoring!
No Jodas
Forget all that noise... only do that if you're in a pinch.
My H22A4 with hasport mounts in a 98' Hatch had Gator axles that never did not have the 'axle bind' issue. It was low and had about 200 hits at the drag strip and never gave me any problems.
