November FS Sticky
Old 11-09-2009, 11:39 AM
  #51
integlspwr2k's Avatar
Default ** FS: Blitz Dual Spec R Boost Controller ** <NEW>
I have for sale a brand new Blitz Dual Spec R Boost Controller.
http://www.blitzpowerusa.com/product...c/dualsbc.html
MSRP: $520
Price: $385 => $370 SHIPPED OR $270 SHIPPED FIRM
Post / PM IF Interested!
Thanks!
integlspwr2k is offline
Old 11-09-2009, 01:15 PM
  #52
94turbosi's Avatar
Default Re: ** FS: Blitz Dual Spec R Boost Controller ** <NEW>
Competition twin disc brand new b series in the box 4-8026c with upgraded pressure plate
still in box and in plastic 1,000 shipped or best offer
94turbosi is offline
Old 11-09-2009, 08:14 PM
  #53
phxpgtt's Avatar
Default Re: November FS Sticky
Ok I have a Hondata S100 with boost option module for sale it is only the module no ecu, the price is $120 shipped please pm if you want it.
phxpgtt is offline
Old 11-10-2009, 02:06 PM
  #54
Innes's Avatar
looking to liquidate these parts -- pictures available upon request
Email -- James@IPGParts.com
Phone -- 407-324-4684
or PM
-- AIR Carbon B16/B18 Intake Manifold -- Set up for 8 Injectors -- includes the lower fuel rail as pictured, manifold flange is drilled for both the B16 and GSR Head Pattern -- Great intake manifold -- what you see is what you get -- $900
-- Function 7 Rear Lower Control Arms for 92-95 Civic, 94-01 Integra -- $140
-- Golden Eagle Scatter Shield for B Series -- $125
-- Skunk2 Composite Fuel Rail for B Series (includes fittings on the end as pictured) -- $100
-- AEM 30-1060 EMS -- $700
-- Complete Fuel System (includes fuel lines with fittings, weldon 2015 fuel pump, aeromotive fuel filters, etc), just add your fuel rail and injectors and you are ready to go -- $750
________________ can include a sumped gas tank for EG as well for an additional cost or will sell individual parts as requested
-- BW S372r Turbocharger -- T4 Flange, 1.10 A/R -- used on a race car so not much mileage at all on the turbo itself, makes great power and nicely priced -- freshly coated black turbine housing -- $1200
-- GSR Cylinder Head with Supertech Valve Springs, Retainers, Valves -- includes the Valve cover as pictured, vtec solenoid and intake manifold gasket -- $1100
-- GSR Shortblock -- 84.5mm AEBS Sleeves with O-rings, Wiseco Pistons, Pauter Rods, AEBS Main Studs, GSR Crank, Moroso Oil Pan, Fluidampr, Circuit Worx Oil Pump Gear, OEM Water Pump, Head Studs -- what you see pictured is what you get
i am selling this block cheap to get it out of here and will recommend the new owner put new piston rings and bearings in it as i am unsure the exact history of the block -- i have taken this into consideration as well when pricing the block to leave room for the new owner to spend the appropriate money to perform those tasks -- $2200
-- OEM Integra Type R ( ITR ) Camshafts -- $300/pair
-- Window Net (needs to be recertified) -- $50
-- 5 Point Harness (needs to be recertified) -- $75
-- Autogage 5" Tachometer with Shift Light, black face, 10k rpm limit - $125
-- FJO Wideband -- complete with sensor, control box and gauge -- $300
-- Honda P28 ECU chipped for a DOHC Vtec Engine -- $140
-- Skunk2 Lowering Springs on OEM Shocks, completely assembled with top hats, etc, ready to bolt on -- fits 92-95 Civic, 94-01 Integra -- $225
or PM
Innes is offline
Old 11-10-2009, 05:32 PM
  #55
91redteg's Avatar
hey i have a set of brand new in the box blox drag coilovers (full set, all four corners), same thing as the omni drags asking 650obo shipped for them
91redteg is offline
Old 11-11-2009, 03:49 AM
  #56
ctr-ek's Avatar
4 fogger kit with warmer and 170 shot -500
Legit b16 trans with LS 5th, 4.7 fd, lsd, carbon coated syncros no grinds or popouts-sold
Brand new Cp piston 83mm 11:1 and Pauter rods with rod bearings pistons are on the rods and the rings r gapped-1100
Gsr head supertech springs and retainer, skunk2 tuner 2 cams skunk2 cam gears, gsr skunk2 manifold is basically brand new- 1100
Complete Type r shortblock-1000
Benson Sleeved Gsr block bored out to 83mm, type r oil pump, gsr water pump, moroso oil pan, fully serviced Ls crank-1400
Type r head supertech flat valves, springs and retainer, ferrea guides, 3 angle valve job skunk 2 manifold, skunk 2 fuel rail, 310 precision injectors, omni 68mm t/b...everything is brand new with zero miles I'm askin 1400
Msd billet dizzy comes with extra jumper harness-sold
Msd 6 digital with coil blaster-250
Avid eg bseries mounts-200 basically new they haven't been on the car for more then a month
Act stage 5 clutch and pressure with act flywheel-250
Act 12lbs flywheel just resurfaced-130
I'm located in northern jersey. Best way to contact me is at 551-556-1069
ctr-ek is offline
Old 11-11-2009, 04:34 AM
  #57
SPOOLINmatt's Avatar
-Precision 1600cc Injectors - 300$ OBO
-FJO Injector Driver - 150$
-MSD SCI-L Box(6A-L) and Blaster SS Coil: 200$ OBO
-Aeromotive A1000 - used, still in proper condition.
235$ shipped.
ALL PRICES SHIPPED!
706-346-6024
SPOOLINmatt is offline
Old 11-11-2009, 10:15 AM
  #58
xtremvw's Avatar
I bought these weld magnum from IPG begining of the year they are 15x9 4x100 5" backspacing paid 852$/pair looking for 700$us
xtremvw is offline
Old 11-11-2009, 12:45 PM
  #59
ALL IMPORT's Avatar
UPDATE!!!
i have decided to sell just the gear stacks as well. so u will get both main shaft & counter shaft complete with all gears syncros ectt. for only 400$
very good deal being to fix 1 gear cost $ 350 plus
FL peepz only !! also as a added bonus if u are willing to travel 2 west palm beach i will even fix your tranny for u for FREE. it doesnt get any better. even if u want the quaif FREE install. few hour job same day fix
HALLA!!
wish i cold find a deal like this back in the day when i had my other trannys, the $$ i would have saved.
for out of state peepz
2000 GSR trans
selling my quaif LSD. 650$
shipped to your door guaranteed to be in perfectly working condition.
can also buy the whole trans as a package deal for only 1150$ shipped to your door also guaranteed to be in perfect working condition. never even had 1 grind, EVER. all syncros still look brand new. as seen in pics.
aslo selling my DSS 5.9 axels & hubs for only 1050$ shipped to your door. work flawless & have never seen power that they are made for. guaranteed to be in perfect working condition & no flaws.
price will come down if your close enough & or live in fL
ALL IMPORT is offline
Old 11-11-2009, 02:08 PM
  #60
MindLess311's Avatar
Motor - JDM GSR Block and Head w/ under 8000 miles since rebuild
CP Pistons 9 - 1
Eagle Rods
ACL bearings
New Water/Oil pump when did rebuild
All new gaskets and seals
ARP bolts and studs through out.
Skunk 2 Intake mani
Chassis - 92 cx with 200000+ miles
6 point cage 5 point harness installed correctly with modded stock seat
KYB AGX shocks all around
Skunk 2 1000lbs springs rear
Aero 450lbs(on car) and spare 350lbs front springs
Blox lower control arms gold
ASR subframe brace
Turbo ish - Full Peakboost FTW kit
35r installed also t3/t4 57trim in good working condition
Tial 38mm wg 50mm bov
Kteller 3" stainless exhaust
Hallman manual boost controller
Large Blitz FMIC and have stock peakboost one was good for 500whp
Electronics - Innovate wide band with gauge
Defi boost and oil pressure gauges
3 bar gm map sensor
Full xenocron tuning set up, ostrich, burner, chips, logger everything you need but laptop and program
Tranny - In car b16 with obx lsd and ls final drive( slightly shorter than gsr)
Spare JDM GSR LSD tranny
Spare set of axles
Spec stage 5 iron disk beefing ****ing clutch
Stock flywheel plus a spare(might be resurfaced already not sure)
Wheels - Rota attacks in gold on car w/ BFG 225 60 15s on front 205 50 15 Falcon Zeix on rear
Custom marsh race wheels with 25/8.7/13 m&h slicks
Set of CRX bowling ball wheels
Looks - CF hood and duckbill spoiler
As you can see i have good about of spares i have a full harness and a half, other random parts and what not. Buy the car you get everything honda i own. No need for me to hang on to it. Control arms, a arms, hubs, bumpers fenders ect.
As of right now car is not tuned for the 35r i might take car of that this weekend but with my new job and everything might not be possible. Warning car is not super clean or pretty it could be but i dont have the time to put in to painting and what not. I always worried about he mechanics not the looks so be forewarned. Car easily runs consistent low 7s in the 1/8 at 104 and mid/high tens at 131+ on the little turbo. Havent ran it on the 35r at all so car has a ton for in it for sure. Times for the car are in my sig.
Looking at $11000 with everything i own honda.
Im sure im leaving a ton out but any questions just ask.
edit: adding **** as i remember here.
New walbro 255 pump and fuel filter this year
AEM Fuel Pressure Regulator
STR Fuel rail
Precision 1000cc injectors
ARP extended wheel studs plus a spare set of 8
B&M Fuel pressure gauge
Omni power camber kit up front
MindLess311 is offline
Old 11-11-2009, 08:24 PM
  #61
JDM_JNKY's Avatar
Email & Paypal: Jdmjnky@yah★★.c★m
AIM: Jdmjunke1
Warranty: All used mechanical parts will come w/ 7-day Money back warranty S/H is non-refundable unless you receive the wrong part.
* Please be sure to read item description BEFORE you PM
* Please BUMP if you view
* I will Ignore low offers/ ballers
High End Tri-Y Header For B-series $300 / $390 shipped obo
* Few small dings shown in photo
* Big tube header
* 1.3/4' primaries
* 2.1/8' secondaries
* 2.1/2' collector
* 304 stainless steel
* USED in good condition
* No gaskets/donuts
GSR Skunk2 Pro Series IM w/ Fuel Rail $225 picked up / $250 shipped
* B18c1 SK2 Pro series IM
* Come w/ Oem Gsr fuel rail
* Will Include used Thermal gasket
* Great Combo Deal
* No sensors
* No TB
* No Injectors
ACT STG2 Pressure Plate, STG1 Disc 10/12lb Flywheel $250 PU / $280 shipped
* Tons of meat on the setup
* Less than 500 miles
* Great used condition
* Fits Any B-series transmission Hydro/Hydro
spline
GSR/TYPE R Oil Pan
$50 Picked up / $60 Shipped
* JDM B18C Oil pan
* Fits b18c1 & C5 engines
* Mint condition
* No dents
B-series AEM TRU TIME Cam Gears $80 PU / $90 Shipped
* Missing One Bolt - Not stripped, just lost it
* Silver in color
* Fits all b-series engines
* Fits H23 I believe
Honda/Acura B&M UNiversal FPR
$40 picked up / $45 shipped
* Used
* Red in color
* Fits any B-series fuel rail ( maybe others)
* Authentic B&M Prod.
96-00 2/4dr Replica Civic SI L.E.D Wing $90 picked up / $100 shipped
* Replica w/ mounting pads
* Spare LED
* Mounting Instructions
* Needs to be repainted to your OEM color
D-series BDL Fuel Rail $105 shipped
* New in the box
* Black in color
* Comes with all hardware
* Bought for D16z6
D-series/z6 Alternator Brkt. $40 picked up / $50 shipped
* Oem Bracket
* Powder coated
* Gloss Black in color
D16z6 Trans-TQ Mount Brkt. $65 picked up / $75 Shipped
* OEM Brkt
* Powder Coated
D16y8 Manual Trans Speed Sensor – VSS $50 picked up / $55 shipped OBO
* fully functional
* needs a exterior clean
D16z6 Speed Sensor VSS $60 picked up / $65 Shipped OBO
* Oem sensor
* Fully operational
* New O-ring
* Cleaned
EF IACV D15b $25 picked up/ $30 shipped OBO
* Fully Functional
* Used in good condition
* Removed in working condition
USDM ITR Exhaust piping $95 picked up – No shipping OBO
* Custom Tailored for EG Hatch
* Header back piping
D16 Big Bore Case Rebuild Kit $300 picked up / $310 shipped
* All new from Honda
* PM me for complete list
* I can use them and rebuild a full tranny (pm me also)
* Fits B000
GSR Polished Post Mount $70 picked up / $75 shipped OBO
* Mint condition
* No cracks
* Great for b-series swap
* Will fit D16 92+ civics
D16z6 Polished Crank Pulley $60 Picked up / $70 Shipped
* OEM Crank Pulley
* Polished to perfection
D-series A/C BLK Powder Coated Brkt. $80 picked up / $90 shipped
* Fresh Coated
* Brilliant Gloss black
* OEM Brkt
* Customize your veh/ appearance
D16y8 Aluminum Oil pan Gasket $10 picked up / $13 shipped
* New from Honda
* Fits y8 or d-series aluminum pans
D16z6 OEM Cam sprocket $5 shipped -Free w/purchase of head
* Used z6
* will include w/ purchase of head
D16 Valve Covers Vented - $45 picked up / $55 shipped - Shaved - $20 picked up /$35 shipped
* One is vented w/ an fitting – don’t recall if it was a 6/8/10 fitting
* Great Condition
* Honda and Rough edges have been shaved
GSR Rear Calipers w/ brkt. comes w/ free F & R rotors – needs turning (R = .33in thick) $50 picked up / $65 shipped special
* No damaged seals
* Fully working caliper set
* Ready to paint
* Great for disc brake swap
* All shims and hardware
* Does not come w/ brake lines
D15/D16z6 & y8 Rage / Whitfield Performance Z6 Cam Gear $115 picked up / $120 shipped
* New never used
* Comes w/ cam key
* Fits y8 when using z6 cam
* Black or Dark Bronze in color
* Key for tuning aftermarket cams
* Hard to find product
D16z6 BUILT Head $800 picked up / $900 shipped special
* Fresh fully ported & Polished ($500)
* Complete Supertech valvetrain - valves, springs, retainers ($500)
* Bronze Valve Guides
* Valve seals
* Flat valves
* 3 angle valve seat
* Resurfaced
* Comes w/ LMA’s – can install w/ purchase of cam
D16z6 Block (bottom end) $450 picked up / $550 shipped special
* Under 90k
* ARP Head Studs ($95)
* Beautiful shine, clean hand polished by me
* KMS Block Guard (Was $80+ shipped)
* New OEM H20 Pump ($60)
* New OEM Oil Pump ($129)
* New OEM Strainer + gasket ($33)
* New OEM Oil pan gasket ($19)
* New Main Seal ($30)
* Oil Pan tapped for Turbo
* Oem Pistons and Rods
Spoon N1 Axle back for HB - EG/EK/DC $340 picked up $375 shipped special
* Willing to ship
* Sound clips avail. on youtube.com
* Mint condition 9/10
* Lightweight 3.6kg
* 110db w/out silencer @ WOT ( also varying w/ piping size )
* Sleek 65mm tailpipe diameter
* Flow rate 139L/sec
* All hardware included for silencer
* Fits DC, EG 2/3dr, EK 3dr
* Silencer reduces noise to 105db @ WOT ( also varying w/ piping size )
96-98 Civic CF Hood-Pending-
* will ship - at your expense, including packaging charges.
* Could use a good cut and buff
* Lightweight, lighter than most cf hoods, I'd estimate 8-10lbs
* Skeleton bottom
* Has pre existing hood pin wholes ( you will receive generic pins w/ purchase-Red)
* I can include Aerocatch locking flush mount hood pins for and adtn'l $95 ( NIB )
* No broken edges
* No cracks
* Unknown brand
* Oem Hood latch striker
* Fits 2/3/4 dr civic
* Will not fit 99-00
- Hard to Find -
$Entertaining Offers 96-98 Civic OEM LIP ( optional )
* Installed Pics can be found using google
* OEM Lip still has 3m tape
* Flat Black color
* All Mounting brackets
* Great Condition 8.5/10
* Becoming a rare find
EK DOHC Authentic Mugen Upper Mount set $140 picked up / $155 shipped
* Needs to be cleaned up
* Genuine Mugen mount set - I have receipt paid $370 back in 03'
* Removed when my motor blew Nov. 03'
* Stiffened poly bushings/stronger than O.E.
* Purchased from King back in 03' through Jason@Rage
USED (k) Mint JDM/RHD EK Ashtray din console w/ harness pigtail & connector $100 picked up / $110 shipped
* Mint condition
* Bought used never installed
* Great Interior Upgrade
* k medium grey
Genuine DC5 H emblem $30 picked up / $35 shipped
* NEW JDM DC5 Emblem
* Purchase from ICB
* Will Fit civic, TSX, Accord
* Ready to ship
Vision B-series CF Spark plug cover $70 picked up / $75 shipped
* New in OG pkg.
* Great weave CF
* All b-series vtec spark plug cover
* Genuine item since 2004
Super rare AE86 Non-smokers console/coin holster $40 picked up / $45 shipped
* Genuine Toyota Part
* Mint condition
* 10/10
* Rare Item
* Fully operational
OEM/JDM EG Amber side markers $10 picked up / $15 shipped
* No harness
* No sockets
* Trade for EK
FRP Mugen TSX replica side skirts $50 you pick up or agree to pay s/h.
* Paid $150 retails above $200
* Mint never mounted condition
* Fits 03+ TSX
* Can be custom Fit 03+ Accord
* Pair of Sides
03-05 Accord/Inspire Replica Mugen ABS Grill $75 picked up / $80 shipped
* ABS Plastic - no chicken wire & FRP
* Painted taffeta white
* Sedan grill
* Can be Modified to fit 2dr
* Oem Fitment
* Great Condition
* No broken Tabs
* Hard to find ABS
Regamaster Decals ( replica ) for a set that covers 5 rims 4 + spare $175 shipped
* $25 ea. per rim or 30 shipped ea. - no paypal fees!
* 6-8yr weatherproof decal
* Yes better than OG decals
* One extra for you spare/ Stupid moments
* 15/16/1718" rims
* comes w/inner barrel decals
96-00 Civic EX Radiator w/ fan ( fan was replaced 6months ago ) $30 picked up / $40 Shipped
* Fan Missing Oem Connector
* Brand New Radiator Cap ($14 value)
* No leaks
Willing to trade for:
16" Authentic Rims-No fakes/Replicas-16" Tires 205/40/16's only-EG/DC B-series billet Hasport/Avid/Innovative style mounts-5x114.3 Conversion w/ 16" ITR Wheels-B-series Turbo Parts - PM me for more info.-Custom Built Turbo Manifold - PM for more info.-Mugen Gen I ITR Wing-Mugen Gen II ITR Wing-1.5 way LSD-GT3076R .78 A/R Divided Turbo-1000cc injectors-USDM OBD-I P72 ECU (Virgin)-EK Hasport/innovative B-series Mounts-70mm Throttle body-3 Bar MAP sensor-Hondata s200/300 for boost-B-series STG.4 6 puck "sprung" clutch kit-B-series Twin Disc Clutch-Bride/Recaro/F1/ or any FIA approved bucket Seat(s)-S2k Clutch Cylinder SIR Cluster 96/8 Only-SIR Sedan Interior-Exterior Paint Job-EK coilover Adj. preferably-EK Sedan Thin side Moldings-EK Sedan Window Visors-EK Billet rear mount-EG Thin Side Moldings-EG6 Bronze Rear Glass
JDM_JNKY is offline
Old 11-12-2009, 09:03 AM
  #62
eddie_ek's Avatar
**********MOTOR Block 600miles freshly built************
B18c1 Earl sleeved 85.MM
Wisco 9.1 pistons
Eagle Rods
Arp head and main studs
Type R oil pump
ATI Damper
Moroso oil pan
*****************HEAD*****************
B18c5 Head
Type R cams
1mm oversized Farrera Valves
Farrera springs and retainers
3angle valve job
Oem timing belt
JG Victor X Manifold
68mm Throttle body
Aem fuel Rail
1000cc Precision INJ
Aeromotive FPR
Aluminum catch can and -10 Braided lines to head and block
PWR Radiator with -16 Braided Hoses
12" slim Fan
All vacumm lines braided -3
Walbro 255 with Relay
Aem fuel filter with -6 braided line
*****************TURBO*********************
Precision PT67R Ball Bearing Turbo
Full-Race Top Mount
Full-Race 3" downpipe
Tial 44mm Wastgate
Tial 50mm BOV
Thermal 3" Full Exhaust
Threadstone 12X3.5X26 FMIC
***************TRANSMISSION***************
2001 GSR No grinds
Typer R LSD
NEW Diff Bearrings
Exedy Twin Disc
*SUSPENSION
16" Rota subzero with scorcher tires
13" front volk rays TE37 with 24.5X8X13 MT slicks
Tien Flex with edfc
Titanium Traction Bars
GSR front and rear Brakes
ARP Front studs
Front camber kit
Rear Camber Kit
*****Chassis 2000 Civic DX NO A/C Clear tittle 2nd owner 52000 miles never wrecked***
Paint Spa yellow thanks to 2001 S2000
Power windows and door locks
Si cluster
HID Hi/Low 10K
AEM EMS
AEM wideband
Si front lip and grill
Caron fiber Hood
EK9 Rear spoiler
EK9 Folding Mirrors
Sorry ebay Rear EK9 replica lip its a B**ch to find oem
Rear tinted windows
greddy turbo timer
Pioneer cd player
Typer R Front seats and shift boot
Stock rear seats
Tenzo steering wheel with NRG short quick release and lock
Honda-tech red H horn button
*************EXTRA PARTS THAT GO WITH CAR*******************
OEM hood spa yellow
OEM mirrors spa yellow
Im sure i left out stuff but its hard to remember everything i have done to it
The best I ran was 11.6@119mph with a 1.68 60ft in 07 the car has been apart in my garage till september 09 havent been to the track since 07 just dyno and tuned new engin to 440hp @14psi
I want 10K complete out the door running car
eddie_ek is offline
Old 11-12-2009, 02:36 PM
  #63
numba 1's Avatar
got a 1995 honda civic ex power everything swapped with a bulit k24 enigine..
car is really clean and well maintained always been garage kept and drivin once in a while..
here are some mods
engine
port and polished fully built k20 head
ferrea valve train and guides
skunk 2 pro 2 camshafts
venom intake manifold
550 cc injectors
golden eagle fuel rail
hasport motor mounts
hondata k pro computer
prp fuel pressure regulater
braided fuel lines
karcepts ac and power steering delete
hytec replica headers
3in piping all the way through to a 3in magnaflow sounds quiet and deep
block
built k24 bottom end
13:7 compression pistons
eagle rods
race bearings
tranny
karcepts shifter kit
04 type s tranny no grinds mint
obx differential
exedy twin disk
interior
integra gsr seats
skunk 2 shift ****
si cluster red needles amber lights
exterior
black housing headlights
blue 10k hids
jdm corner lights
carbon fiber hood
mugen front lip
16in charcoal slips fresh tires
skunk 2 control arms and mid dc bar all chrome looks great
50 50 tail lights
m3 trunk lip
very clean body
car made 291 hp tuned by yosolo..........really looking to sell for 10500 car also comes with 24 in slicks and cut out race doors with pexi glass, ihave the original ex doors on the car... also looking for trades only infinity g35 coupes or honda s2000 other than that cash please dont waste my time if no money...cars def worth the money you will not be disappointed..call or text 201 245 1567 thank you
numba 1 is offline
Old 11-12-2009, 03:15 PM
  #64
Mr Rex's Avatar
itbs for sale h22 injectors not included
1000 plus shipping
Mr Rex is offline
Old 11-12-2009, 04:35 PM
  #65
Mr. Badwrench
boostedcivicsir's Avatar
msd 75611 programmable rev limiter box. works with all analog boxes.
http://www.msdignition.com/Products/...v_Control.aspx
Too much power can actually be a hindrance when it comes to hooking up a small tire or the prop of a drag boat. For anyone with this “problem” the Programmable Launch Limiter is the answer. This microprocessor controlled Limiter plugs in place of an rpm module in an MSD Ignition or Soft Touch unit. You can then go in and program a launch-based rpm ramp based on rpm and time. This is set in 100 rpm steps down to 0.001-second increments by using MSD’s Pro-Data+ software on a PC or with the optional Hand Held Monitor, PN 7550. There is also an adjustment that sets a delay time before the rpm limit activates. This way, when you launch the rpm limit will kick in exactly when you want it to and ramp up to your race rpm for the rest of the run. This Limiter can be used with most of MSD’s Ignitions or Rev Controls (except the 7AL-3 and 10-Plus) that use the plug-in rpm modules. The Pro-Data+ software is supplied.
the box is 2 years old, plenty of length on the wires. well taken care of. i think we are getting a handle on the car without it.
testing waters, but if interested,
200 shipped.
boostedcivicsir is offline
Old 11-16-2009, 05:44 AM
  #66
Turbo-charged's Avatar
bullseye power S372 turbocharger. race cover was cut off in a lathe with 5" vband welded on. perfect for those that want to make an intake. turbo is pretty much brand new. car started and idled with it on there and thats about it. $1250. also have standard cover if anybody is interested in just the cover or purchasing the turbo with standard cover.
Turbo-charged is offline
Old 11-16-2009, 08:31 AM
  #67
boostfeen's Avatar
F/S..NRG-tech Built & Tuned SFWD EG Hatch
-93cx clean title
-2yr old paint
-10pt cage NHRA certified
-Stroud window net and parachute
-Morroso Battery box relocated to trunk
-Morroso Kill switch
-Custom Batt. charging terminal located next to Batt.
-Engine bay painted flat black w/ wire tuck
-Carbon fiber hood
-Sparco hood pins
-VIS carbon duckbill spoiler
-Type R style front lip
-Custom Rear Bumper diffusers
-AEBS sleeved B20 block
-Micro polished LS crank
-84mm coated JE Pistons 10:1
-Pauter Rods
-ATI race Damper
-Rotating assy. balanced by Miller
-Type R Oil and water pump
-Golden Eagle Oil Filter Sandwich plate
-Morroso Oil pan w/ GE magnetic drain plug
-B16 Head
-Race port and polish by Miller
-Supertech Springs & Retainers
-Supertech 1mm oversized Nitrate Valves
-Golden Eagle Cam seal
-Golden Eagle Head studs
-Brian Crower Cams
-Skunk2 pro series cam gears
-Toda Timing belt
-JG Edelbrock port matched IM
-Hondata IM gasket
-Ericks Racing 74mm TB w/ Addel Wiggins Clamp
-AEM 5bar Map sensor
-Powder coated and vented valve cover
-NRG custom Breather tank w/ 6 -10 lines
-PWR Aluminum Radiator w/ high power Fan
-12an Coolant Lines
-Morroso coolant Overflow Catchcan
-B16 Tranny w/ Quaife LSD
-Competition Clutch Twin Disk
-Honda MT Fluid
-Golden Eagle Scatter Sheild
-DSS stage 5 axels w/ ARP extended Studs
-Avid Racing Solid Billet Motor mounts
-Full-Race T4 Topmount
-Precision Turbo 74mm Qtrim .96ar w/ upgraded shaft
-4in Stainless DP w/ V-band and wrapped w/ thermo-tec
-Tial 60mm WG custom mounted by BigTom
-Dump tube wrapped w/ thermo-tec
-Precision 750hp IC back doored on one side
-3in. Alumin. IC piping all around
-Twin SX engineering Fuel pumps
-Paxton Fuel filters
-Competition Engineering Fuel sump
-10an fuel lines
-NOS Y Block
-Golden Eagle Fuel Rail
-Aeromotive Fuel regulator
-Summit Fuel Sample valve
-Precision 1600cc injectors
-FJO injector Driver
-M&W Pro10 ignition
-Crane Coil
-MSD spark plug wires
-NGK plugs
-Hondata S300 w/ boost by gear
-Hondata Boost Solenoid
-D2 Drag Coilovers 18k rear 12k front 32way adjustable
-Skunk2 Front camber kit
-Omni power Front LCA's
-Full-Race Traction bars
-Skunk2 rear LCA's
-Benen Industries rear lower arm bar
-Russel Stainless brake lines
-Power Slot slotted rotors
-Hawk HP pads
-Black Rota slipstreams 15x7 4x100
-MT Drag Radials 225x50x15
-Sparco Pro2000 Seats
-G-Force 5pt. Harness (driver)
-NRG Innovations Slim quick release
-Mugen Steering wheel
-Mugen Pedel kit
-HOP Radio delete plate
-JDM SIR Gauge Cluster
-JDM accessory Din Station
-JDM type R shift boot
-Spoon Shift ****
-GSR shift linkage w/ ES poly bushings
-Broadway rear view mirror
-Apexi boost gauge
-Defi Oil press. gauge
-Defi EGT gauge
-Auto Meter Water temp. gauge
-MSD LED shift light
...I will post up some updated pics when i get a chance. Again, this car was bone stock when i got it.
..Everything was done by NRG-tech racing and it shows. PM me with any Q's you may have. Im sure i left some things out, there is just way to much to list. thanks for looking.
. The price for this sick EG is now 18k. If you dont like, it keep it movin. Lowballers will be ignored
I will NOT part out so dont ask. Bump if you look. Thanks.
Pics of how the hatch sits now
boostfeen is offline
Old 11-16-2009, 09:03 AM
  #68
TopEndUSA's Avatar
Selling for a friend:
That's right im selling my "60 trim" ITS turbo which has no shaft play and doesn't smoke at all. The turbo is proven to be able to make 400hp on my 1.8 lsvtec motor.
Im also selling the intercooler, piping ,t clamps and couplers with the turbo.
$400 takes it all.
"60 trim" Turbo proven to make 400hp on my 1.8 liter lsvtec
Enough cut and uncut piping to plumb just about any Honda for intercooling.(most of the piping is bead rolled)
All the couplers and t-clamps to secure all the piping.
One stock DSM BOV that hold my 21lbs of boost. Its uncrushed.
And the black painted intercooler that ive been using which is smallish.
http://i21.photobucket.com/albums/b2...EG89/turbo.jpg
http://i21.photobucket.com/albums/b2...iv-pipe-25.jpg
http://i21.photobucket.com/albums/b2...ntercooler.jpg
I need to clarify to everyone that hasnt seen my set up that the piping illustrated above is not the exact piping being sold. The pic is just something very similar that I bought on ebay and cut up into a million pieces to fit the rex. But I do have quite a few uncut sections left over from other kits ive owned and they will all go with the sale. Some of the piping is silver polished and the rest is black. Anyone who has seen my set up in my CRX knows what they are getting. The turbo is fantastic and spools just fine with zero shaft play and no smoke.
TopEndUSA is offline
Old 11-16-2009, 09:20 PM
  #69
ef9civicgen4's Avatar
Default JoJo Callos CRX 3pc Front End
Just like the title says, its brand new with white primer. In perfect condition, never been mounted or anything. Uses the JDM bumper lights. Can be adapted to fit an EF hatch or 4 door.
there is almost a 3 month wait for these, if you ever even get it at all. heres one in town you can check out in person before you buy it.
PM me if youre interested and ill give you better contact info. This is in the Kansas City MO area, and its pick up only. I will not try to ship something this large and fragile.
ef9civicgen4 is offline
Old 11-17-2009, 05:08 AM
  #70
sgnlab's Avatar
Time to move on!
https://honda-tech.com/forums/drag-racing-36/my-sfwd-setup-something-like-2478493/ <<<MY Build Thread
All of these parts have dyno time and one run up the track! I am in NO WAY AT ALL IN A RUSH! PLEASE LOW BALLERS STAY AWAY DONT EVEN TRY IT. I know my prices are more than fair! THANKS FOR LOOKING!
gsr tranny with racer steve hardened gears, mfactory lsd, mfactory 1st gear, carbon synchros, all new bearings and seals, welded belhousing, 5th gear cuff.. $2,000
BW s372 with standard cover $900
garett core 24"x12"x4.5" with charge pipes, and 72mm TB all hargett clamps 3" piping $1,500
avid pro solid mounts $250
Rywire EK obd2a Engine Harness $650
Hondata s300 with pwm and obd2a connector $700
M&W Pro 10 with coil and T1 Milspec harness $500
edlebrock intake manifold b16/typer $225
FLUID Damper with steel hub $300
Moroso B series Oil Pan SOLD
2 44 tial wg's one blue one black $250 each SOLD BLUE WG
1 tial Q BOV Black $200
id2000cc injectors SOLD
exospeed ek front end SOLD
Tunerview dash with molded bezel SOLD
Level 3.9 axles with hubs SOLD
5 bar t1 map sensor with pigtail $100
Sleeved Benson gsr Block 83mm SOLD
Pauter LS rods $550
Benson Machine LS Crank $200
cnc port ported type r head 1mm intake valves (includes supertech springs valves retainers keepers vtec solenoid) Need Minor repairs SOLD
Comp Twin Disc $800 about 300 miles on it
NRG Tech Magic Stick Cams $600
Lenso Slicks and skinnies brand new with 1 run on the slicks SOLD
PeakBoost Twin Scroll Turbo Manifold SOLD
Omni Power Suspension 1 run on them SOLD
Complete dual 044 fuel system (Filters, Lines, pumps, regulator and fittings) SOLD
Wilwood Brake setup with brake lines (Complete) $400
Catch Can Setup with breather lines and welded valve cover $600
bdl cam gears $100
96EK Civic with 10 point CM roll cage Carbon hatch and hood painted to match $2500
sgnlab is offline
Old 11-17-2009, 06:39 AM
  #71
GDD Moderator
tony tone's Avatar
Icon7 PFU 042-0950
I have a set of 1000cc precision injectors that have never been used. I bought them to replace my 550cc injectors from my GSR, but have sold the car since then. They're never been installed let alone taken out of the foam that's inside the box. Part number: 042-0950. I also have a steel braided fuel line with an AN fitting on 1 end as well as a HP fuel rail that I'll throw in with it if I get asking price.
I will take more pictures if you like. I'm asking $225 SHIPPED, obo. I accept paypal and money orders/cashier's checks. I'm located in Miami if you wish to pick up.
PM me, or email if you have any questions. Thanks!
Tony
edit: SOLD
tony tone is offline
Old 11-17-2009, 07:48 AM
  #72
skunk2allmotor's Avatar
FOR SALE:
competition clutch 4 puck sprung and pressure plate 280 shipped.
toda flywheel mint 325 shipped
msd 6al 120 shipped
2 step module 50 shipped
clutch and flywheel have 4 miles on em
skunk2allmotor is offline
Old 11-17-2009, 09:08 AM
  #73
.CUBISH.'s Avatar
custom 4-1 ssr header with reverse cone/megaphone
3" v-band collector
stainless
fits eg/dc and ek
made for a k24
$1000
brand new in the box wiseco 13.7 to 1 pistons
87.5mm k20/k24
$400
used for about 15 dyno runs
cp 12 to 1 pistons 87mm for k20/k24
$200
.CUBISH. is offline
Old 11-17-2009, 11:42 AM
  #74
toddvw's Avatar
aeromotive A1000 pump with check valve
asking $200, pump was rebuilt by aeromotive little over a year ago
toddvw is offline
Old 11-17-2009, 10:54 PM
  #75
ludicrous's Avatar
Brand New Eagle H-beam rods
with ARP2000 bolts
used JE pistons 10:1 compression (8,000miles?)
for 94-01GSR
rods and pistons ARE BALANCED and is numbered for each other
NEEDS new rings and locks and should get new wristpins
$350+shipping+paypal for the whole set-up
http://i82.photobucket.com/albums/j2...v/DSC03571.jpg
http://i82.photobucket.com/albums/j2...v/DSC03577.jpg
http://i82.photobucket.com/albums/j2...v/DSC03584.jpg
GoodYear 28x10x15 slicks
1 pass...
$125+shipping+paypal for both
(and no, I did not run these, if some ppl may wonder)
http://i82.photobucket.com/albums/j2...v/DSC03605.jpg
http://i82.photobucket.com/albums/j2...v/DSC03610.jpg
http://i82.photobucket.com/albums/j2...v/DSC03612.jpg
http://i82.photobucket.com/albums/j2...DSC03613-1.jpg
pm or e-mail me at d1dc2nv@yahoo.com
More pic's can be provided if want.
thanks
Mike
ludicrous is offline
Quick Reply: November FS Sticky
