No antifreeze in cooling system for drag racing right...? - Honda-Tech
Old 05-08-2007, 01:05 PM   #1
Mikey3000's Avatar
Default No antifreeze in cooling system for drag racing right...?
I understand this is done so if you happen to spill onto the track, water alone is much easier to clean up. With that being said, do you use distilled water and how much water wetter? One bottle or two?
Mikey3000 is offline   Reply With Quote
Old 05-08-2007, 01:09 PM   #2
* B A N N E D *
Default Re: No antifreeze in cooling system for drag racing right...? (Mikey3000)
Distilled water and 1 bottle water wetter works like a charm!
R.S.AKIMOTO is offline   Reply With Quote
Old 05-08-2007, 01:14 PM   #3
NooB
IT'S ME DAVID's Avatar
Default Re: No antifreeze in cooling system for drag racing right...? (R.S.AKIMOTO)
Dasani
IT'S ME DAVID is offline   Reply With Quote
Old 05-08-2007, 02:09 PM   #4
Better than steak
Arturbo's Avatar
Default Re: No antifreeze in cooling system for drag racing right...? (IT'S ME DAVID)
I use what ever comes out of the water hose. lol
Arturbo is offline   Reply With Quote
Old 05-08-2007, 02:11 PM   #5
camp1320.com's Avatar
distilled and 1 bottle of water wetter will do the job.
i hate tap water cus it builds up calcuim and rust
if you have a built block you can afford to spend $2 on some distilled water.
Tap water
camp1320.com is offline   Reply With Quote
Old 05-08-2007, 02:42 PM   #6
Mikey3000's Avatar
alright one more thing that just came to my mind... is it mandatory to have open ended lug nuts so the tech inspectors can see that the stud penetrates all the way thru the lug nut?
Old 05-08-2007, 02:53 PM   #7
akaRacerX023's Avatar
You should have extended lugs and open lug nuts for slicks.
akaRacerX023 is offline   Reply With Quote
Old 05-08-2007, 02:57 PM   #8
Default Re: (akaRacerX023)
no antifreeze
Migrana is offline   Reply With Quote
Old 05-08-2007, 03:06 PM   #9
* B A N N E D *
Default Re: (Migrana)
Quote:
+ tap water kills the inside of an aluminum radaitor...
Old 05-08-2007, 03:12 PM   #10
MrParks's Avatar
Default Re: (R.S.AKIMOTO)
mmmmmm.... tap water
MrParks is offline   Reply With Quote
Old 05-08-2007, 05:23 PM   #11
vaporboy12's Avatar
Default Re: (MrParks)
tap water and a few drops of dish soap here
vaporboy12 is offline   Reply With Quote
Old 05-08-2007, 08:53 PM   #12
Richard...'s Avatar
Default Re: No antifreeze in cooling system for drag racing right...? (camp1320.com)
Tap water
+ Also distilled water and water wetter will cool far better then anti-freeze will!
*Heat kills performance*
Richard... is offline   Reply With Quote
Old 05-09-2007, 08:31 AM   #13
SPOOLINmatt's Avatar
Default Re: No antifreeze in cooling system for drag racing right...? (richard7968)
interesting thread, im gonna try this. water wetter and just water.
SPOOLINmatt is offline   Reply With Quote
Old 05-09-2007, 09:25 AM   #14
d16dcoe45's Avatar
Default Re: No antifreeze in cooling system for drag racing right...? (SPOOLINmatt)
I always hear about people using a few drops of Dawn instead of Water Wetter in their radiator. I know that the soap will reduce the surface tension of the water (which is basically what water wetter does) but I wonder if there is more to it than that? I mean I have always ran 1/2 bottle of Water Wetter in my radiator but are a few soap drops just as effective?
Also, as was previously stated--pure water is more effective at taking away heat from your engine compared to an anit-freeze mixture. Anti-freeze exists for three reasons: To prevent freezing of the block, to increase the temperature at which plain water boils, and to prevent corrosion of the radiator and block. It doesn't cool as well as plain water though.
That is the whole point of a higher pressure radiator cap, it doesn't help cooling per-se, all it does is raise the point at which water or anti-freeze will boil. Once the coolant starts boiling even a little its heat transfer properties go to ****.
As long as you don't reach the temp at which coolant will boil, plain distilled water is a better choice in hot climates. I believe water under 1.3 bar of pressure will boil at something like 250 degrees, while a 50/50 mix of anti-freeze and water at the same pressure will boil at around 260-270. Those numbers might not be exact but its somewhere in that range.
d16dcoe45 is offline   Reply With Quote
Old 05-09-2007, 12:43 PM   #15
Richard...'s Avatar
Default Re: No antifreeze in cooling system for drag racing right...? (d16dcoe45)
according to the redline water wetter bottle it says on there that it has properties in there to lube your water pump and prevent rust and all of those negative things your talking about
all i can say is try it and you should love it!
Old 05-09-2007, 01:36 PM   #16
fmfkid250's Avatar
I put plain water in my stock sleeve built motor and I swear to this day it rusted my h ead gasket causing a leak....so antifreeze it is for me!
fmfkid250 is offline   Reply With Quote
Old 05-09-2007, 01:54 PM   #17
BolivianFuego's Avatar
Default Re: (vaporboy12)
Quote:
Are we talking about cooliing or stripping your old layer of wax?
BolivianFuego is offline   Reply With Quote
Old 05-09-2007, 04:00 PM   #18
taggart_lumpy's Avatar
distilled and water wetter here
taggart_lumpy is offline   Reply With Quote
Old 05-09-2007, 09:49 PM   #19
Richard...'s Avatar
Default Re: (fmfkid250)
Quote:
IF you put the water wetter in there it has additives that protect against that kind of thing happening
Old 05-10-2007, 05:11 PM   #20
NLR
NLR's Avatar
Default Re: (richard7968)
cycle logic engine ice.
propelyne glycol and deionized water.
NLR is offline   Reply With Quote
Old 05-11-2007, 11:52 AM   #21
DixielandImports Please
ReDemoN's Avatar
Default Re: (NLR)
Is this just for full drag cars or street cars?
ReDemoN is offline   Reply With Quote
Old 05-12-2007, 12:07 AM   #22
NLR
NLR's Avatar
Default Re: (ReDemoN)
both
Old 05-12-2007, 12:44 AM   #23
V-SPEC 1's Avatar
Default Re: (NLR)
Where can we get this stuff at? thanks.
V-SPEC 1 is offline   Reply With Quote
Old 05-12-2007, 08:30 AM   #24
Ginger Kid
pomansouth01's Avatar
propelyne glycol is the active ingredient in antifreeze if I am not mistaking...
pomansouth01 is offline   Reply With Quote
Old 05-12-2007, 12:27 PM   #25
Richard...'s Avatar
Quote:
both
LOL
if it's good enough for the track it's good enough for the street!
WTB: OEM Honda Oil Pump, Water Pump, And Timing Belt! secondz Want to Buy 6 03-19-2012 10:52 PM
how much would you pay for a gsr block with oil and water pump jesstopher2nr Honda Civic / Del Sol (1992 - 2000) 4 09-14-2010 04:31 PM
Testing waters...sell '05 R1? SWE3TDUDE Honda Motorcycles 8 02-01-2007 04:16 PM
Timing belt/water pump change - how much coolant is needed? erikiksaz1 Acura Integra Type-R 6 08-27-2006 08:45 PM
Is anyone using Redline Oil's Water Wetter? TypeRod Acura Integra Type-R 8 08-10-2002 01:27 AM
Tags
antifreeze, antifrezze, coolant, cooling, distilled, drag, drags, fluid, freez, race, racing, radiator, system, tap, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
