New Garrett GTX-R turbos look wicked
#26
Re: New Garrett GTX-R turbos look wicked
I don't think they spend a lot of time on refining the turbine wheels, because the models they have now work well with engines bigger than what we use. Having only four cylinders affects how much exhaust gas we can flow through an engine to get the turbo moving. They could probably develop better performing exhaust wheels specifically for us pretty easily just like the comp wheels, but they would still be pretty difficult to make. I don't know if there would be enough demand to justify having them developed from a manufacturer standpoint.
#27
hope the gr35r is getting some love pretty soon.. A compressor wheel that that will make the turbo puching a little more boost would be greate.. hoping fore just changeing the wheel and have it rebalanced and make it a 700-750 hp turbo..
#30
#31
OG Fabricator
Theres plenty of options for that right now! forced performance or precision and 750whp wont' be a problem.
#32
That would be very cool.. never heard that you could upgrade a garret gt35r with a billet precision 62mm wheel.. Where is that available?? Can it realy be rebalanced too?
To bad I live in Sweden.. It costs alot to send the turbo to US for upgrade.. Is it possible to order the parts and have the conversion done at some turboshop over here?
#33
If this is true that you can uppgrade a garret gt35r with a PTE billet presision wheel I would order a twin entry T04 gt35r with a 6262 compressor right away.. That would be the best gut damn turbo ever.. If the ballbearings can stand the side loads at higher boostlevels that is..
#34
I dont think precision will sell just a wheel seperate. I had asked a local shop (precision dealer) to get me one and they said no. They only sell them installled. Maybe they changed???
Adriano
Adriano
#35
+1!
Same as the regular GT series, hence the name.
#37
Let me be the dudge of that.. Is there anyone that knows where it can be done?
#38
I am a precision dealer and I have done these types of upgrades many of times. Please pm me for information.
#41
Very nice!
#45
#46
I saw these at PRI. Your right, the majority of turbos back in the day were full bladed like this.. A full blade turbo traditionally was good for higher pressure at lower compressor speeds and had less total airflow range, this was good for steady state diesel stuff, but not as good for engines with a wide operating range. The turbo manufacturers went to the "Splitter Blade" because they found that leaving a gap between every other blade allowed the air to be grabbed by the blades more easily at higher compressor speeds increasing the usualble airflow range of the turbo. Aparently the old school fin designs were not good at grabbing inlet air at really high speeds and the split blade solved this issue. So it looks like from the new compressor maps posted by garrett that they have come up with a full blade design that is the best of both worlds. The new compressor maps show much higher pressure ratios and slightly more flow.
I also agree that there needs to be more focus on the turbine side.. There are so many compressor wheels available now as it is, and the turbine side is where our options are rather limited.. Personally I think that proper turbine design is much more important to the total performance of the turbo in a real world on engine situation.
We will be doing a back to back against this:
As for putting work into the turbine wheels, Garrett already has some of the best turbine wheels in the business. When you look at power vs exhaust pressure, I have routinely seen the Garrett wheels out pace many other manufacturers given the same size wheels and same A/R housings. Obviously not 100% of the time, but they definitely have some of the best turbines in the business.
4294 - 94mm, 4202 - 102mm, 4508 - 108mm
Here are some more pictures of the turbos:
http://www.realstreetperformance.com...?g2_itemId=895
#47
Why would they care for the OE's demands in their motorsports division where these units are meant for or as they say they are meant for?
Does the rumor that garrett made these wheels for a OE manufacturer and the wheels didnt perform as promised and this was a last ditch effort to sell them?
There are alot of speculations as to why garrett has switched to this design and the real truth will be told on the track if they work or not. No dyno numbers are going to tell the real story.
#48
I know what's next up on the build sheet, when you see the next turbos come out, the statement about OE contracts will start to ring true even more.
The rumor mill will always keep running, as you said, we will find out what they do in the real world. Garrett is one of the most forthcoming brands in terms of the information they provide on their turbochargers. Their compressor maps are normally on the money. What Garrett has told me was the move to the 11 blade and lack of splitters was for the quieter operation that the OEs are looking for.
I'm a Garrett, PTE, Turbonetics, BW, Holset, Mitsubishi, Exile, Forced Inductions, etc... distributor and/or associate distributor, I don't really have a reason to push one brand over another, so our data will be unbiased.
As far as dyno numbers, that depends if the dyno numbers are tinkered with. Using fuel is using fuel - I know about how much power it's making if it's using __% of ____cc injector with a __ base pressure on _____ fuel, the math doesn't really lie when it comes down to fuel consumption. What it comes down to is the honesty and the bias of the person posting the information.
Regards,
Mark Conte
#50
