My k20 turbo not so baller build
#51
#52
#53
Re: My k20 turbo not so baller build
Got the intercooler mocked up again
i was able to fit the intercooler without having to cut the grille off the bumber,but had to cut the bottom of the radiator support
#55
#56
#60
#61
Ended up getting a new turbo unit afterall..Precission pt6266 1.0ar
Parts just laying around waiting to be installed
Hpt guide
Got bored so I ended up doing a brake tuck haha
Could've been cleaner work if I had the right bender👎
Finally was able to install the new twindisc
#63
#64
#65
#66
#67
#68
lol maybe thats why mine sucked I was doing a double flare as i have in the past with a matco flare tool. Matco tool worked perfect, this autozone unit is horrible. Its mostly the tools fault, for when you do the first flare it makes it off center. So when you try and use the cone the second time it flares to one side and isnt centered. Im guessing i just got lucky the last time i used one....
#69
#71
#73
came across this clean 08'tsx longblock so I went for it..would make it a nice back up motor👍
Couldn't help it to strip the car up and get it ready for paint
#74
do the rear brake lines, "from prop valve, out of cabin to engine bay, then are they routed underneath the car, can you show some pics of that,?
thanks, sweet build. always looking for updates
#75
