My EG Drag Car
#53
Re: My EG Drag Car
Just started the engine!
Then, I need to buy a KOYO radiator and put the battery in front of the car (Driver side)
because the big oil catch tank is at the battery location.
#54
Re: My EG Drag Car
Still don't know what to do with all these ABS wire (Orange plugs!). I disconnected everything but don't know if I can cut all these wires!
#57
Re: My EG Drag Car
Just installed my KOYO radiator and 310mm Spal
Some problem to fit the cap, is it normal?
How many miles before boosting do you advise?
#61
Re: My EG Drag Car
After 200 miles I started boosting!
12PSI, and tires spin a lot, it's Winter here and road are very cold. I hope this is the reason lol
In 4th gear around 80MPH tires still spin !
Other point, I think I have problem with boost creep with my AFI Turbo manifold and 1 x Tial 44mm.
#62
Re: My EG Drag Car
#66
Re: My EG Drag Car
Yes I know afi is well know I've had two of their manifolds the first a top mount that had to have both flanges milled cause they were warped so they didn't sit flush on the head...my ram horn had boost creep. Nobodys perfect.
#67
Re: My EG Drag Car
My too it is the second AFI manifold.
The first Front facing doesn't fit with OEM half radiator and there were 2 tial flange, and the second has boost creep problem and only one W/G port.
I sent them an email,
#71
Re: My EG Drag Car
Victor X is a good intake manifold and very good price.
Here is a little vid of my car last night
http://www.facebook.com/video/video....d=220911217950
I need to change my "chineses" tires to real Drag Street tires!
You see the check engine light because past 7500RPM is go to 15PSI to 22 PSI.
Didn't yet change the W/G spring to a lower one
