mmr rear/spindle wheel????
i know its gonna be hard to tell but judging by this pic, do u think i can remove the hub/rotor and switch to a spindle mount wheel similar to the nuformz setup with a new rotor???
Re: mmr rear/spindle wheel???? (allmotor92civic)
The nuformz setup is acutally Lamb and strange components... the spindle is intergrated into the strut... so you would have to somehow mount a new strut to your solid axle...
anything is possible if work is put into it...
Re: mmr rear/spindle wheel???? (newspeedR)
when i take the hub/rotoe assembly off, it looks the same as the nuformz spindle, but its hard to tel w/o a spindle mount wheel
Re: mmr rear/spindle wheel???? (newgsr)
That is a strange spindle with a lamb strut. The kit is sold by Nuformz, not a MMR (MB products) full race.
[Modified by turbohonda, 6:36 AM 1/7/2003]
Re: mmr rear/spindle wheel???? (turbohonda)
ill try to get a pic w/o th hub/rotor and eveyone can get a better idea of what im talkin about.
I run the MB (mmr) set up on my car, it actually is similar to a spindle mount in design where the hub actually is a plate which bolts onto the QA-1 shock, then there are chromoly arms which bolt on the stock mounting locations. it's a nice setup and worked pretty good for me. what is nice is you can run reg. wheels or bogarts not $350 a piece spindle mount wheels. I am actually selling my set up fromlast year if anyone is interested($2,000, regularly $3200) I am custom making something else. My stupid brain keeps writing checks my wallet can't cash.
Re: mmr rear/spindle wheel???? (quick1723)
hey sav,
can you tell me more about your penske setup? what's the advantages? would a japanese shock w/ remote reservoir adj. rebound & compression be comparable?
Re: mmr rear/spindle wheel???? (SEFI8LOxCivic)
the advantage of the penske shocks is the tunability at the track. Penske did alot of research on these shocks strictly for drag racing so the adjustment range is for launching and weight transfer. A japanese shock w/ remote reservoir would work well but those shocks are more than likely designed for road racing.
thanks for the info sav, i think im just gonna stick with my new weld wheels instead of getting spindle mount. it was just an idea i had to try to squeeze a little more weight off the car
Thanks!
Congrats on your season championship, Sav.
frankybonez
Acura TL, RL & ZDX
10-29-2006 05:53 AM
