M&W Pro10 Hookup/Install Diagram
Just wondering if anyone has a diagram for a M&W Pro10 Series 2 install on Honda. Need to know pinouts on the M&W and the distributor wires I need. The car is a 00 GSR. Will be running stock distributor with M&W Pro10 and a Crane coil.
look on the m and w ignition website. i belive its www.mwignitions.com or something along those lines.
other than that. you will need to use the icm output from the ecu to trigger the box. give it a constant 12 v, ground(these prefebly hooked to battery) , and key on 12v.
i belive it would need pin 11 looped to pin 3. you can check with an oclliscope (spelling)
Better Yet. forget what you are doing, give Tony a call. hes done it more than once before, i know of multiple peoples cars running flawless on his Ign harness setup. 214 607 9022. his harness' are made from good quality, proper sized wire, as well as have proper crimps on them. all color coded and come with literature.
cabledude4619
Audio / Security / Video
03-06-2012 05:51 PM
