King Engine bearings? Anyone use them? If not what do you use? - Honda-Tech
Old 07-07-2010, 10:05 AM   #1
Drag4Life723's Avatar
Default King Engine bearings? Anyone use them? If not what do you use?
I have used ACL duraglide and race bearing on about 95% of the engines i have built. I used a set of kings about 5years ago with good luck. With the whole ACL failing at life with the price jump and the intergalactic back order on b18/b20 bearings i need to get some and would like to hear what every one is using out there.
Thanks
Russ
Drag4Life723 is offline   Reply With Quote
Old 07-07-2010, 10:35 AM   #2
DixielandImports Please
ReDemoN's Avatar
Default Re: King Engine bearings? Anyone use them? If not what do you use?
I used a set of kings in a factory rebuild.
Worked ok.
As far as I know its still driving.
That was 4 years ago
ReDemoN is offline   Reply With Quote
Old 07-07-2010, 12:05 PM   #3
Redline130's Avatar
Clevites have worked well for me so far.
Redline130 is offline   Reply With Quote
Old 07-07-2010, 12:53 PM   #4
Why not just order ACL bearings from an online store that has them in stock?
E85B18 is offline   Reply With Quote
Old 07-07-2010, 01:14 PM   #5
B18c1turboedEK's Avatar
Quote:
Who carries them? I've been looking and noone carried them in stock I guess.
B18c1turboedEK is offline   Reply With Quote
Old 07-07-2010, 01:20 PM   #6
http://www.maperformance.com/honda-a...gine-bearings/
Plus Im sure there must be a number of H-T sponsors that have them in stock
Old 07-07-2010, 01:23 PM   #7
Justin Jones's Avatar
King is a really good bearing if you ask me, I used them in my B18C build.
Justin Jones is offline   Reply With Quote
Old 07-07-2010, 01:27 PM   #8
I called and emailed over 60 companies in and out of the US no one has them.
Quote:
yep!
They dont have them.
Old 07-07-2010, 01:51 PM   #9
E-Town4229's Avatar
Quote:
are you talking about OEM?
-Roger
E-Town4229 is offline   Reply With Quote
Old 07-07-2010, 02:13 PM   #10
nope already checked. I guess everyone drop ships them only.I'm just going too get OEM and be done with it. I can't wait 11weeks
Old 07-07-2010, 02:16 PM   #11
EGhatch87's Avatar
Quote:
x2
EGhatch87 is offline   Reply With Quote
Old 07-07-2010, 02:17 PM   #12
Yeah the ACL thing sucks. we do have mains/thrust acl race but are out of the rod bearings for B16 and LS motors. I believe I have a few sets of B18C HX rod bearings too.
ACL Says end of July. I also have the full set of Clevite in stock with the H rod bearing. Been having to use that with the whole ACL fiasco.
RealStreet is offline   Reply With Quote
Old 07-07-2010, 05:08 PM   #13
Quote:
-Roger
there duraglide and race bearings like i stated in the OP.
Old 07-07-2010, 05:09 PM   #14
Any of the Outlaw and SFWD guys have any certain bearings you like???
Old 07-07-2010, 07:17 PM   #15
I have used King in my last motor they held up great and are still holding up in a friends chassis
Boosted-EH-804 is offline   Reply With Quote
Old 07-07-2010, 07:41 PM   #16
regamaster's Avatar
they do not make them hardened like the ACL bearings are (1925h)
If they would actually have them hardened, they would sell a lot better. For race motors, they are not too good. they cant take a beating especially at high rpm.
regamaster is offline   Reply With Quote
Old 07-07-2010, 07:49 PM   #17
non-VTEC's Avatar
king bearings here....making over 400whp with them. no problems. actually the last 3 or 4 engine setups i went thru all used king bearings...never a bearing related failure/problem. they seem to work just fine...they can take the abuse...
non-VTEC is offline   Reply With Quote
Old 07-07-2010, 08:04 PM   #18
I dont know were you got your info but according to king there HP bearings hard just like the ACL Race.
Old 07-08-2010, 07:15 AM   #19
96 GSR-T's Avatar
Contact Laskey Racing I got a full B-Series ACL Bearing set for $100 shipped, cant beat that!
My old motor had King's in it, never had a problem with them.
96 GSR-T is offline   Reply With Quote
Old 07-08-2010, 07:56 AM   #20
tony1's Avatar
Why not just use OEM Honda? That's all we use in our motors.
tony1 is offline   Reply With Quote
Old 07-08-2010, 11:11 AM   #21
Diller's Avatar
My father used to sell their bearings in the late 90's. He swears by them. He has them on a 800hp 460 that was built ten years ago, has at least four hundred passes on it and still going strong.
Diller is offline   Reply With Quote
Old 07-08-2010, 11:35 AM   #22
turbotypeR@SPEC's Avatar
Only OEM Honda here! I have used others, but none compare to Honda! Period.
turbotypeR@SPEC is offline   Reply With Quote
Old 07-08-2010, 12:47 PM   #23
DIABOLIC8's Avatar
OEM bearings are what I hear most people use, I have never heard any bad things with the oem honda bearings.
DIABOLIC8 is offline   Reply With Quote
Old 07-08-2010, 03:08 PM   #24
BubsBoostedEG's Avatar
i use oem in my higher hp car 800whp and clevites in a 400hp sohc both i have had good luck with prefer oem tho, recomend playin with the colors to get proper clearances for high hp if useing oem, good luck
BubsBoostedEG is offline   Reply With Quote
Old 07-08-2010, 04:01 PM   #25
mike93eh2's Avatar
Quote:
that is what i was thinking.. theyre the best to use in my opinion and the only ones i use in engines i build.
mike93eh2 is offline   Reply With Quote
B16 EAGLE RODS bearing crush hight RACEPAK Engine Machining & Assembly 1 05-22-2016 05:42 PM
B16 Engine Acl pistonrod bearing sanjay2 Tech / Misc 1 06-14-2010 08:21 AM
Kings Bearings made of Tri-Metal or Bi-Metal? hmtcrxsir Honda Civic / Del Sol (1992 - 2000) 2 06-07-2009 02:42 AM
rod bearing ? dohcgarage@714 Acura Integra 2 03-01-2008 06:33 PM
king's main bearing poorman's type-r Acura Integra 1 05-09-2006 02:58 PM
Tags
b18b, bearing, bearings, canada, clevite, engine, forum, honda, king, kings, ls, review, reviews, si, tech, vtec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
