J series Insight Build
Old 01-20-2017, 06:53 PM
  #76
bauergold's Avatar
Default Re: J series Insight Build
Originally Posted by hondaracing84
Nice! Keep the updates coming!
What intake manifold is that kit for?
Pretty sure it's for a holley lsx manifold.
Maybe he just got the flanges to make a custom plenum though.
A big forward facing plenum would be cool!
Old 01-23-2017, 06:42 AM
  #77
hondaracing84's Avatar
Oh right. I wasn't thinking that the p2r kit was for the holley manifold. I knew that, lol.
Old 01-24-2017, 09:25 AM
  #78
ChokeOnMySmoke's Avatar
Old 02-11-2017, 04:47 PM
  #79
Throttle body on
AD Engineering adjustable cam gears (close up)
AD Engineering Idler arm brace
AD Engineering manual timing tensioner
Mounting the CSF (king cooler) radiator to see what we have for room up front
Old 02-14-2017, 03:18 PM
  #80
Wireworx j series harness with fuse box and switch panel option.
Direct plug and play into aem infinity
Old 02-14-2017, 03:28 PM
  #81
scottp11's Avatar
Great job so far!!! The attention to detail is amazing!
I plan to use the Wireworx harness as well. Let us know how everything fits and any modification needed if necessary.
Again, great job!
Old 02-15-2017, 01:38 PM
  #82
Thank you I appreciate the kind words. I will let you know how the harness works out for sure. Quality is all there I was blown away when I recieved it for sure. Hope it works as well as it looks.
Again, great job!
Old 03-09-2017, 03:13 PM
  #83
Another piece to the puzzle
Old 03-15-2017, 05:50 PM
  #84
Cody Athan's Avatar
This is incredible!
Old 03-16-2017, 05:46 PM
  #85
Originally Posted by Cody Athan
This is incredible!
Thanks man still a long way to go.
Old 03-16-2017, 05:49 PM
  #86
Old 03-27-2017, 10:00 AM
  #87
scottp11's Avatar
Any updates? Have you connected the harness yet? Do you know what wire-worx did with the VSS and if the speedo will work? If you don't mind saying, how much did your harness run you?
Sick build, again and I look forward to any and all updates!
Old 03-30-2017, 05:05 PM
  #88
No havent connected the harness yet. Still collecting the final pieces to the puzzle. Harness was around 1400 all plug and play to the infinity box. Ill be using some sort of aftermarket display racepak most likely. Thanks again
Old 03-30-2017, 05:07 PM
  #89
P2R version 2 fuel rails arrived today. Few more pieces to the puzzle then the fun can begin.
Old 03-31-2017, 12:55 AM
  #90
scottp11's Avatar
I recently ordered the same fuel rails, along with some other parts from P2R. Let us know how they fit and if any modification is needed. I read on J32A.com that the injectors are a little tight on these rails, and that the holes needed to be chamfered.
Old 03-31-2017, 08:43 AM
  #91
850Fabrication's Avatar
man you really need to consider a stepped thinwall header in the future. what size weld els are those? if you are using 1.5" (1.9" OD, 1.75"ID), that runner is too small and will become a very large restriction on the engine regardless how big you make the choke to overcome the restriction
Old 03-31-2017, 11:48 AM
  #92
Those headers were for mock up only to see what we would and wouldnt have for room. We are doing a stepped header. Should be finished in a week or two.
Old 03-31-2017, 11:50 AM
  #93
This is P2R version 2 fuel rail. All the issues are fixed with this one. I slipped the injectors in today perfect fitment.
Old 04-03-2017, 08:19 AM
  #94
Fabrication time
Old 04-03-2017, 08:24 AM
  #95
scottp11's Avatar
Can't wait!
Old 04-03-2017, 09:14 AM
  #96
Looks great. Cant wait to see it finished!
Old 04-04-2017, 01:21 PM
  #97
SwappedTURBOegg's Avatar
i spy matts bmw lol you friends with him too?
Old 04-06-2017, 03:44 AM
  #98
Yes sir. All guys I grew up with racing.
Old 04-14-2017, 08:19 PM
  #99
Old 04-16-2017, 06:00 PM
  #100
sirtef9's Avatar
Looks mean, cool build!
Quick Reply: J series Insight Build
