inital startup on s300
hey guys i just got my car running last night its a itb 13:1 compression lsvtec. it starts with the map in the car, and when i first start it, my plx wideband reads right around 14.7:1. so i let it idle and after about 20 seconds it starts going leaner and leaner and leaner till i have to shut it off. i added a bunch of fuel in the low speed fuel table, with no changes to the gauge. so i added 10 psi fuel pressure and the exact same thing happened again. right now the cars open header and the o2 is mounted probably 6 inches from the end of the header is it possible air is coming in the tailpipe and throwing off the reading? this is my first major buildup and first time with a standalone. any help would be greatly appreciated. thanks in advance
Shaun
heres the buildup of the car is your interested
https://honda-tech.com/zerothread?id=1364932
Shaun
Re: inital startup on s300 (nvmyb20hatch)
Reversion/dilution is probably affecting your O2 readings. On a full throttle pass on the dyno, open header O2 readings can be inaccurate up to about 3,000 rpm. After that rpm the A/F readings tend to be more reliable.
Re: inital startup on s300 (b19coupe)
the reason its reading 14.7 for the first 20 seconds is because the wideband is heating up...thats nto an accurate number...the wideband will read that until its hot and then read correctly....If your using the software that came witht he s300 it needs to updated...they released a **** program with it and that was the first major problem...
what size injectors are you running? update the software and then add to the overall fuel trim till it gets right
pm me if you need help as you cant expect it from hondata
go to option on the top and check realtime update..
that will help with the adding fuel and not getting any results..
seth
seth
96hatchBoy
04-14-2013 11:27 AM
Black R
02-12-2002 04:38 PM
