Staged Injector Setup
Hey ,
I'm going with a new setup and I got the Edelbrock 8 injector manifold. I plan on running 8 bosch 1600cc injectors I'm trying to figure out the best way to wire them up. Do you just piggy back of each injector? And do i run them as staged or do all 8 work at the same time
My fuel and ems consist of
E85 fuel
Aem series 1 EMS 1040 box
Aem Injector Driver
Weldon 2025 pump
weldon fpr
-10 feed
-10 return
duel fuel rails
-10 Y into both rail
E85 fuel
Aem Injector Driver
Weldon 2025 pump
weldon fpr
-10 feed
-10 return
duel fuel rails
Re: Staged Injector Setup
You can run them either way. When I ran AEM, I ran them staged. Four 550cc injectors were running solo until about 5psi where my 1600 transitioned into. AEM works great for the staged injection. Read the manaul and it will explain it more.
Wire each injector seperately as the AEM pinouts show. I seriously suggest reading the manual and instructions and then report back. There are 8 different ecu pinout locations for the injectors on that box.
