How often are you guys changing your fuel filters?
Old 04-02-2014, 11:14 PM
a1320honda's Avatar
Default How often are you guys changing your fuel filters?
I have a sumped tank with a -8 outlet going to a 10 micron filter. Then goes to the A1000, from there to an aeromotive 100 micron filter. Seems like im changing the post pump filter every 3 months or so of street/track duty. Pulled the pump apart and everything is good in it. Thinking about changing the pre filter to a 40 or 100 micron. BUt dont wanna be spending $150 on 2 filters every 3-4 months. Guess i should post, im using pump E85.
Old 04-03-2014, 03:11 AM
rudebwoy's Avatar
Default Re: How often are you guys changing your fuel filters?
Why don't you use filters with stainless steel element so you clean them instead of replacing them?
Old 04-03-2014, 03:29 AM
Turbo-LS's Avatar
You should have the larger micron filter pre pump and the smaller micron post pump. Get your self a 60 micron stainless steel filter before the pump and depending what injectors and fuel you should have 5-10 micron after the pump.
Old 04-03-2014, 10:18 PM
.adam.'s Avatar
ditto on the stainless element, ive got the cheap summit ones and they just screw apart. you can remove the element and clean it in a couple minutes
Old 04-04-2014, 08:52 AM
jskillzva's Avatar
^^^^ what this guy said. Had an issue with one of mine ever since then I carry a can of carb cleaner and clean both before and after an event.
Old 04-04-2014, 10:03 AM
rudebwoy's Avatar
advice. do not use small filters, get a big one, the small ones clogs very easy.
Old 04-04-2014, 04:04 PM
92cxturbo's Avatar
What turbo ls said you have your microns backwards. Get a stainless unit so you can clean it. I just picked up a 10 micron stainless unit from b&r gitttings. I had always read you can only get 10 micron in fiberglass to be e85 compatible, but they had them in stainless when I called to place an order.
Old 04-04-2014, 04:26 PM
SPOOLINmatt's Avatar
huh. Ive used 100 pre and 60 post ss elements for quite a while.
Old 04-04-2014, 04:56 PM
jdm inc's Avatar
get yourself a stainless steel filter instead.
Old 04-04-2014, 05:02 PM
92cxturbo's Avatar
According to ID injectors your taking a risk using anything bigger then a 10 micron pre injector
Old 04-04-2014, 10:37 PM
1lowek2007's Avatar
I wonder why it would be a risk being that most ID injectors have 7 micron filters in the tops.
steveo34609
04-11-2011 07:14 AM
BOOSTWERKS
Mid-Atlantic (Sales)
01-05-2009 06:08 AM
Halo
02-11-2003 10:21 AM
Quick Reply: How often are you guys changing your fuel filters?
