Hickam's 67mm Matte Black Turbo Hatch
#52
Re: Hickam's 67mm Matte Black Turbo Hatch
Started the new motor up last night but for some reason the thermostat isn't opening and water temp got up to 210* so we shut it off.
#55
#57
Has water temp but not fuel level. Kept the water temp just to keep the cluster centered.
The cluster has a serial port that reads everything that the Kpro signal puts out. It can read:
Water Temp
Air Temp
AFR
Volts
RPM
Speed
Odometer
Boost/Vacuum
And some more... It won't work with s300 though.
Water Temp
Air Temp
AFR
Volts
RPM
Speed
Odometer
Boost/Vacuum
Nice build looks great. What dash unit is that?
#58
It is the AIM MXL Strada. Still need to set it up for my preferences.
The harness bar is a bit too low. I got the car with the 6pt already in it and raising the harness bar 3" is something I still need to do. I was planning on doing that when I add oN to the cage and add front bars and to make the car a little bit more safe
#60
Also got the car running right last night. The Stant 180* thermostat wasnt opening even at 210*. Took it out and it opened in boiling water. Went ahead and left it out to make sure that was my problem. My fan also wasn't turning on but when I took the thermostat the fan came on. Sucks that I double checked all of my k series conversion harness when I had it all hooked up right the first time.
Just need to do a few more things so I can take it to get it tuned.
Dumptubes
4" aluminum exhaust
bleed clutch and brake lines
move the fpr and run a 4" intake tube for the turbo
Dumptubes
4" aluminum exhaust
#65
I will be installing a hybrid racing chain tensioner, Spunktek chain guide, supertech valves, retainers, and springs, and some Brian Crower Stage 3 cams.
#66
#67
HELLO,GOOD MORNIN'
i see why it messed up, cause walter touched it..lol J/k. Man those silly setback come but you will get it worked out. Now the heads all warped and hopefully it didnt get so hot the deck warped..sucks. You'll get it though.
#70
matts the man with the master plan! glad you finally got her up and running sorry i diddnt get to txt back been busy workin overtime buddy. lemme shoot some video of the car now!
