Gator Axles VS Drive shaft shop.
Old 12-29-2006, 06:25 AM
  #26
Danny_EJ's Avatar
I run DSS stage 2 axles with 400whp more launches than I can count - had them for a long time and never one issue.
On the other hand I have seen a 190whp integra snap a set of DSS stage 2s, and saw a Bone stock integra with just Skunk2 cams snap a DSS stage 3 from a 1-2 WOT shift. So it just goes to show nothing is invincible.
If you dont launch properly you can break any axle
Old 12-29-2006, 06:59 AM
  #27
Turbo Wax's Avatar
Default Re: (Danny_EJ)
any more feed back on those guys ?
http://www.axlesystem.com
Old 12-29-2006, 07:00 AM
  #28
tony1's Avatar
Default Re: (Turbo Wax)
Go with DSS, buy 1 stage more than you "need", and you'll never have to worry about them.
Old 12-29-2006, 08:09 AM
  #29
mr2mitch's Avatar
A buddy of mine went through 3 sets of gator axles on a turbo type R (496hp).
It ended up being the way they were sitting due to his ride height.
Not sure if this was a gator problem or somthing that would have to any set of axles. Just fome FYI
Old 12-29-2006, 08:26 AM
  #30
ninesecrx's Avatar
Default Re: (mr2mitch)
The new DSS stuff is even more amazing then ever! The new level 2.9's are even stronger the the level 3's used to be. With the level 2's, they are a direct bolt in which is nice for the people that were making the power and needed the level 3's like before.
Old 12-29-2006, 09:20 AM
  #31
boosted_TSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Wax &raquo;</TD></TR><TR><TD CLASS="quote">any more feed back on those guys ?
http://www.axlesystem.com </TD></TR></TABLE>
i know a lot of racers using them for drag and for road racing.
Tony has built axles for Canadian Drivers Stephan Beauregard, Paul Bhawan, Joe Conde etc...
hes got lots of Hub and axles set-ups
Old 12-29-2006, 02:13 PM
  #32
Jason703Racing's Avatar
Default Re: (boosted_TSi)
so for 500whp on a turbo hatch, stage 3's is the way to go im guessing?
Old 12-29-2006, 03:04 PM
  #33
mrbh22's Avatar
not to put anyones product down but i personally saw a guy with the level 5 dss axel setup with the hub snap one at norwalk this year.and i left gator a message one day to call me about my axel setup and i i did get a phone call from them, until about 3 weeks after i left them the message. just my .02
Old 12-29-2006, 03:55 PM
  #34
1 2 NV's Avatar
your FYI is fairly valid. the so called "stage 3s" that i broke were even on my car with my motor tilted to help alleviate the misalignment issue.
Old 12-29-2006, 07:23 PM
  #35
5thgearburnout's Avatar
Default Re: Gator Axles VS Drive shaft shop. (Black00em1)
If you are worried about breaking you axles just do what gator does. Buy stock parts stick them in the oven for awhile call them "heat treated", spray paint them green put a couple stickers on them and charge people way to much for STOCK PARTS!
Old 12-30-2006, 02:46 AM
  #36
Default Re: Gator Axles VS Drive shaft shop. (5thgearburnout)
hhahahahaha
Old 12-30-2006, 04:17 AM
  #37
nonvtecallmotor's Avatar
Default Re: (mrbh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbh22 &raquo;</TD></TR><TR><TD CLASS="quote">not to put anyones product down but i personally saw a guy with the level 5 dss axel setup with the hub snap one at norwalk this year.and i left gator a message one day to call me about my axel setup and i i did get a phone call from them, until about 3 weeks after i left them the message. just my .02
</TD></TR></TABLE>With those driving methods he would of broke tank axles. You cant wheel hop all the way down the track and exspect not to brake anything.
&lt;--- Just bought DSS stage 5's
Old 12-30-2006, 05:03 AM
  #38
boostfeen's Avatar
Default Re: Gator Axles VS Drive shaft shop. (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">They shouldn't even be compared, DSS is on a whole different level. DSS </TD></TR></TABLE>
agreed. shame on you people who try to compare gator garbage to DSS.
i rock the old stage 5's, but from what i hear the new 5.9's are tuff..
...contact Miller or Big Tom on here for unbeatable prices on DSS axels.
Old 12-30-2006, 09:42 AM
  #39
dropcivic's Avatar
Default Re: Gator Axles VS Drive shaft shop. (boostfeen)
we broke 2 gator axles, first on the driver side, then on the passanger side. H22a with type-s pistons and a 125 shot, still at stock height too. Didn't even get off the line. Still have the gators but i will not use my radials on the car untill i get a trailer. If they break again, hello DSS.
Old 12-30-2006, 10:58 AM
  #40
Default Re: Gator Axles VS Drive shaft shop. (dropcivic)
sounds like gator is some trash.
Old 12-31-2006, 02:19 AM
  #41
Darrell Bs 10SecEG's Avatar
I use DSS and I only broke them one time out of 4 passes.I have 44PSI at 846WHP H22.The DSS are for sure strong.I never used the Gators but Ill try them out next and see how much abuse they can handle.It also depends if what size slick and pressure U use.I went from 24.5 to 25 and at 25,U start to break ****.U can use 24.5 by 9s and U should be okay from 500-700WHP.It all depends on your set up.Every set up does something different and depends on how stiff your suspension is.Good Luck.Darrell
Old 12-31-2006, 09:10 AM
  #42
AllMotorMark's Avatar
real good shafts thats what i run, great customer service
axle system all the way
Old 12-31-2006, 05:10 PM
  #43
B18 CYA's Avatar
Used DSS Stage3's with 424whp this season with no problems at all.
Old 01-02-2007, 11:14 PM
  #44
bigTom's Avatar
Default Re: (B18 CYA)
DSS does not even compare to gator. We use DSS in many of our customers cars without problems. We had a few customers using the Gator stuff and in the end ALL of them broke.
I highly recommend any of the DSS stuff.
Old 01-03-2007, 03:15 PM
  #45
Default Re: (bigTom)
i got DSS stage 3's today from inline pro. Deff good deal and thanks stan for haven them instock
Old 01-04-2007, 05:01 AM
  #46
D-Rob's Avatar
Default Re: (Black00em1)
I've been running the same set of DSS Stage 1's through two setups over the past 3 years now.
I've only got a couple passes on slicks on them, but I beat the snot out of them daily.
Old 01-04-2007, 07:26 AM
  #47
OG Fabricator
9bells's Avatar
Default Re: (D-Rob)
This is interesting. I was looking to buy axles, and one of the local racers
told me never to buy DSS. He had broken a few sets of stage 2's, and had gotten fed up, switched to Gator, fine since. I bought based on his experience, and have been fine with mine on slicks so far.
Hopefully I don't experience any problems.
Really wish I had known about the canadian guy, would of tried him first.
Good thread.
Old 01-04-2007, 11:14 AM
  #48
ninesecrx's Avatar
Default Re: (9bells)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9bells &raquo;</TD></TR><TR><TD CLASS="quote">This is interesting. I was looking to buy axles, and one of the local racers
Good thread.</TD></TR></TABLE>
You have to look at the whole picture. The stage 2's have been discontinued and are now 2.9's. Also, maybe he was doing something with them he should have have been or even running them on more hp/tq then they were rated for. Either way, good luck with the axles you have bought
Old 01-04-2007, 07:20 PM
  #49
92eg6's Avatar
Default Re: (ninesecrx)
a friend of mine borke his old stg 5's which i guess are now stage 3s? at 610 hp in third gear on the 1st run...twice!!! but he now has the new stage 5s and they have yet to break
Old 01-09-2007, 08:56 AM
  #50
tmac007's Avatar
Default Re: Gator Axles VS Drive shaft shop. (1 2 NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dropcivic &raquo;</TD></TR><TR><TD CLASS="quote">we broke 2 gator axles, first on the driver side, then on the passanger side. H22a with type-s pistons and a 125 shot, still at stock height too. Didn't even get off the line. Still have the gators but i will not use my radials on the car untill i get a trailer. If they break again, hello DSS.
I had 2 dss stage 4's break center shafts like this, for a 2g set of axles I was unimpressed, 2 seperate cars in the same week. Now I only use axle systems, for $500 the refurbished the broken pair to their stage 4's, which use stronger shafts and internals and they're pulling strong.
Not that im knocking DSS or anything, they do make a nice product. But for the cheaper price of the axle systems set i will be sticking with them unless the let me down repeatedly.
Quick Reply: Gator Axles VS Drive shaft shop.
