FTW, c16, q16, e85, let's talk fuel - Honda-Tech
Old 07-16-2012, 08:43 AM   #1
Tuner Eddy's Avatar
Default FTW, c16, q16, e85, let's talk fuel
Hey Guys,
I'm headed to my tuner in a few weeks and wanted some opinions on fuel. I do not run my car on the street, only the track. Now that my car is back together and running well, I want to turn the boost up. I'm currently running 11 psi and the car made 278whp and 200tq at this level. I plan on tunign the car on 30psi when I hit the dyno.
I have access to c16 and e85, but all of these talks about FTW and q16 have me wondering which is the best option. Correct me if I'm wrong, but FTW fuels are e85 based, correct? My goals are getting the car into the mid 10's, I feel that 500-550 will get me there.
Thanks for any advice.
--Ryan
Tuner Eddy is offline   Reply With Quote
Old 07-16-2012, 08:51 AM   #2
tepid1's Avatar
Default Re: FTW, c16, q16, e85, let's talk fuel
If I were you I wouldn't even consider FTW or Q. It's very expensive and your goals are achievable in anything you mentioned before. c16 or E85 would be my choice if your fuel system can support it. Hell, Cam2 will get you there as well.
tepid1 is offline   Reply With Quote
Old 07-16-2012, 08:57 AM   #3
Tuner Eddy's Avatar
Quote:
Thanks man!
I just didn't know if the others made more power or were better for the motor. I don't care the cost on each fuel, more worried about what is better for my motor and more efficient.
c16 and e85 are locally available though, so I'm guessing they are a more practical choice.
Old 07-16-2012, 09:00 AM   #4
sanman000719's Avatar
pump e85 here and in the mid 700's with it.
now as mentioned your fuel system is the main ingrediant, but i did manage 650 on 1000cc injectors and an a1000 fuel pump. oh yeah and a great tuner wont hurt
sanman000719 is offline   Reply With Quote
Old 07-16-2012, 09:14 AM   #5
Tuner Eddy's Avatar
Guess I should list my fuel setup:
In Tank Walbro 255
Inline Bosch 044
Inline filter
PTE 1000cc injectors
AEM rail
Aeromotive regulator w/ gauge
Old 07-16-2012, 09:20 AM   #6
200 HP's Avatar
Quote:
Originally Posted by Tuner Eddy View Post
Hey Guys,
--Ryan
Considering that you mentioned your car is strictly a track car, if you have the $ then I would highly recommend FTW Purple to get the most power out of your setup. It is an ethanol based fuel but with much higher quality and consistency than you will find at the pump.
200 HP is offline   Reply With Quote
Old 07-16-2012, 09:26 AM   #7
Tuner Eddy's Avatar
Quote:
I'm fine with $33 per gallon and with buying it 5 gallons at a time.
Thanks for the advice. You guys are all giving some good information.
Old 07-16-2012, 09:45 AM   #8
surfingsk8r's Avatar
Best bet is to ask your tuner what fuel he would prefer to work with for your setup IMO.
surfingsk8r is offline   Reply With Quote
Old 07-16-2012, 10:11 AM   #9
a1320honda's Avatar
Its not to hard these days, about 5 years ago i made a little over 500hp on pump gas and an ebay 60-1 at 19psi and went 10.6@138 in a 2550lb car. Also using an intank walbro, stock lines, stock regualtor and PTE 1000's on Crome lol. And using an A1000, -8 feed, aeromotive regulator, and PTE 1600's and pump E85 made 721whp at 24.5psi.
a1320honda is offline   Reply With Quote
Old 07-16-2012, 10:40 AM   #10
meane30's Avatar
Dang, I wish we had your kind of money to spend on fuel! We run pump e85. $3.xx is a lot better then $33 a gallon for a mid 10second car IMO. Do what you want, you will make more power with FTW
meane30 is offline   Reply With Quote
Old 07-16-2012, 11:10 AM   #11
Tuner Eddy's Avatar
Quote:
I have to call him this week, so I'll ask him which he is comfortable with.
Quote:
Wow man! Nice. I'm running a single cam though, so I think 500hp on pump would be tough.
Quote:
Well, i look at it as a hobby. I'm running a d2b with a 6262, so I need all of the help I can get. I work to play, so I'd like to make sure I'm putting the best stuff in this car. If running FTW Purple is only going to gain me 10whp, then I see no reason in running it. But with a single cam, and my whp goal is 500+, I'm all for anything that will help me achieve that on the lowest boost possible. I've just guessed that ~30 psi will get me to that mark. I always think low, and the car will be tuned as high as my tuner is comfortable with, I like to be surprised I guess.
Old 07-16-2012, 11:28 AM   #12
Kelvin Racing's Avatar
Since it's in the area get e-85
Kelvin Racing is offline   Reply With Quote
Old 07-16-2012, 11:52 AM   #13
The fueling the world line of fuels is not for everyone and I totally understand that. It is expensive but dolla for dollar for what it is does is worth it to many.
As far as power gains I can't say an exact number but 10hp is far from I have seen the average 500+ hp gain. I would say you would be in the range of 50hp. Not trying to sell you on it as I understand it's not for everyone but for the ones who want the most out of their setup and want a large tuning window this fuel is for you.
miller is offline   Reply With Quote
Old 07-16-2012, 12:52 PM   #14
In Tank Walbro 255
Inline Bosch 044
Inline filter
AEM rail
You're gonna need to stick with gas with that setup. Ethanol based fuel will tap that system out quick.
Divers is offline   Reply With Quote
Old 07-16-2012, 01:56 PM   #15
twkdCD595's Avatar
For gas and being your not concerned with budget as much... Q16 is probably going to be the best route.
C16 would easily support your goals though, Q just will make a little more being that it is an oxygenated fuel.
twkdCD595 is offline   Reply With Quote
Old 07-16-2012, 03:07 PM   #16
Tuner Eddy's Avatar
Quote:
Is it the injectors?
Old 07-16-2012, 03:25 PM   #17
Yes. The single 044 won't get you too far but the injectors are def you main limiting factor right now.
Old 07-16-2012, 03:34 PM   #18
Miller did you not do some testing q16 and vp import how close is the vp to the ftw if you will share.
heavy duty is offline   Reply With Quote
Old 07-16-2012, 03:41 PM   #19
rs250nut's Avatar
Who is the distributor for the ftw fuel in Europe?
rs250nut is offline   Reply With Quote
Old 07-16-2012, 04:01 PM   #20
bebe1320's Avatar
I've been vp 116 guy for so many years..however a lot of people going e85...."class permitting"if ur not in a class run alky....the benefit to e85 over alky is it has almost the same characteristics but with e85 you don't have run gas in it at the end of the day as u would with alky...with good fuel u can throw more timing at it without gearing the detonation ....You will also need nearly need twice the amont fuel with alky.so u need a more demanding fuel setup..
bebe1320 is offline   Reply With Quote
Old 07-16-2012, 04:28 PM   #21
Quote:
I have done this testing and so have a few others. I can tell you that I have seen very considerable gains over any gasoline I have tested it against. I would like for people to make their own decisions on the fuel after testing it themselves or seeing it first hand.
Quote:
I have been talking to people and shops alike all over the world and like any product it will take time to setup distributors all over the world.
Please email us at sales@ftwracingfuels.com and we can go from there.
Old 07-16-2012, 05:07 PM   #22
evilone's Avatar
why race fuel, i tune a lot of evo's most of which we don't even think about anything other than 93 octane til at least 600, i don't see why you would need it to make 500-550. unless you just want a better tuning window. vp ms109 works really well on the other hand
evilone is offline   Reply With Quote
Old 07-16-2012, 05:23 PM   #23
Tuner Eddy's Avatar
Quote:
I haven't heard of many single cams doing 500-550 on pump, I could be wrong though.
Old 07-16-2012, 06:15 PM   #24
evilone's Avatar
Missed the sohc part
Old 07-16-2012, 07:41 PM   #25
utahturbosohc's Avatar
c16 will be more than enough for your goal. My fuel system is the same (with the exception of the injectors, I have bosch 1000's) and motor/setup is almost identical. We easily made it past 600hp on c16. and would be easier on the pocket book vs other fuels on your list. Minus e85. like they said, fuel system would be an issue there. And I've always been afraid of consistency with pump ethanol. Our local pump is never the same.
utahturbosohc is offline   Reply With Quote
Fuel choices PSI GUY All Motor / Naturally Aspirated 6 09-13-2015 07:13 AM
ID1700 all the are cracked up to be? Who runs them? 94eg5squadMD Drag Racing 1 09-05-2015 08:08 PM
DDTECH Testing: FTW FUEL, Header, Nitrous DDTECH Forced Induction 4 03-23-2015 09:13 PM
my official build thread! ef_ftw73 Acura Integra 32 05-01-2014 08:33 AM
new race fuel! Fuel The World (FTW-purple)!! Turbo-charged Forced Induction 40 02-26-2014 05:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
