December FS Sticky
Mr. Badwrench
December FS Sticky
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 1-1-2010, any edit to these threads, will result in sanctions. if it persists, the stickies will disappear for good.
4) NO WTB ADS!
Mr. Badwrench
Re: December FS Sticky
msd 75611 programmable rev limiter box. works with all analog boxes.
http://www.msdignition.com/Products/RPM/Timing_Controls/RPM_Controls/75611_-_Programmable_Launch_Rev_Control.aspx
Too much power can actually be a hindrance when it comes to hooking up a small tire or the prop of a drag boat. For anyone with this “problem” the Programmable Launch Limiter is the answer. This microprocessor controlled Limiter plugs in place of an rpm module in an MSD Ignition or Soft Touch unit. You can then go in and program a launch-based rpm ramp based on rpm and time. This is set in 100 rpm steps down to 0.001-second increments by using MSD’s Pro-Data+ software on a PC or with the optional Hand Held Monitor, PN 7550. There is also an adjustment that sets a delay time before the rpm limit activates. This way, when you launch the rpm limit will kick in exactly when you want it to and ramp up to your race rpm for the rest of the run. This Limiter can be used with most of MSD’s Ignitions or Rev Controls (except the 7AL-3 and 10-Plus) that use the plug-in rpm modules. The Pro-Data+ software is supplied.
the box is 2 years old, plenty of length on the wires. well taken care of. i think we are getting a handle on the car without it.
testing waters, but if interested,
200 shipped.
200 shipped.
b16 52mm twm with injectors $1000. sold
fully built long block GSR with b16 head $4500 this motor made 980whp.
95 GRS long block it has about 90000miles $1100.sold
NEW 85mm RS pistons with rings $200. sold
B- series NEW skunk2 stage 1 cams $350.
B-series used skunk2 stage 2 cams $350.sold
NEW skunk2 B-series SRINGS and RETAINERS $250.
NEW BLOX 76mm throttle body $220.sold
93 civic The CircuitWorx Stage 2 drive AXLES, HOPS, INTERMEDIATE SHAFTS AND SPOOL. $1000. sold
simpson Parachute $200.
STRANGE drags 800 rear, 550 fronts coil overs $900.
LSL T4 Twin Scroll Manifold $500
Tial 50mm bov $ 150.
4" Down Pipe $100.
4" core intercooler
3" IC piping $500.
DriveTrain:
NEW G-FORSE Dog Box transmission
gears 2.92 1.88 1.43 1.12 with 2 final drives 4.0 and 4.73
$4000.sold.
hyro Tilton twin disc clutch with only 5 passes $900.
cable Tilton twin disc clutch it only seen dyno $900.
95mm eagle crank $350.
NEW 95MM crower cranks $450.
call at 619 278 8337 ask TB. .
4" Down Pipe $100.
4" core intercooler
3" IC piping $500.
DriveTrain:
$4000.sold.
Brand new Spec H&F series Triple Disc Clutch SH14MT3 never used only bolted up for mock up. $900.00
all b series,was only on the car for 500 miles so pretty much new located in GA 706-767-0195
300$ PFAB log manifold w/ T3 Flange selling with downpipe
200$ Tial 38mm Waste Gate w/gasket and dumptube
50$ Gm 3 bar map sensor with pigtail
230$ Rc engineering 750cc injectors
275$ JE 81mm 9:1 pistons that need rings
185$ B16 Eagle rods w/ big rod bolts $450$ for pistons and rods
180$ clutchmasters stage 3 clutch hydro tranny only 1000 miles on it supported 400 hp no problem
[/QUOTE]
[/QUOTE]
PM me with interest and dibs, so when I make up my mind you get what you called dibs on. Thanks
Safety:
3 nozzle fire suppression system $175 shipped
Head & valve train:
-H22 Cylinder Head. Ferrea dual valve springs, Ferrea titanium retainers, Ferrea valves, Head has a stage 5 race port & has been polished. 3 angle valve job, New OEM valve and cam seals, vented -10a/n valve cover. SOLD
-Custom TopEndUSA H22 Turbo Cams AEM adjustable Cam gears SOLD
Block:
-H22A1 with Darton Sleeves, Crower rods, Arias pistons, High flow oil pump, Kaizen Speed balance shaft elimination kit, New Honda bearings and seals, ARP Head head studs $1800 shipped (pending sale)
Intake system:
-Venom intake manifold $350 shipped
-STR 70mm billet throttle body $175 shipped
Turbo system:
-Stainless steel tubular T4 turbo manifold faces compressor forward $500 shipped
-4 inch custom downpipe $300 shipped
-Borg Warner S372 turbo with small cover 1.10 exhaust made 745whp at 35psi $1050 shipped
-Custom PWR Water to Air intercooler with Ice Box, water pump and lines $600 shipped (pending)
-Synapse BOV $100 shipped
Fuel system:
-Aeromotive 1,000hp -10AN fuel pump, SOLD
-Aeromotive Fuel pressure regulator, SOLD
-STR fuel rail SOLD
-Precision 1600cc injectors SOLD
-Custom fuel sump Integra DA tank $250 shipped
Engine Management:
-P28 with s300 installed (SOLD)
-Custom OBD1 race wiring harness one piece design $330 shipped (dibs to PRO1)
-MSD Digital 6 SOLD
-2 x MSD HVC Coils (SOLD)
-AEM Injector Driver SOLD
Cooling system:
-Fluidyne 3 core radiator SOLD
-Summit catch can (SOLD)
-Spal high flow fan $45 shipped
-Innovative mounts alternator relocation kit $60 shipped
-New Optima redtop battery $140 shipped
Transmission & driveline:
-Circuitworx Drag spool, with bearings, no speedo gear. $300 shipped
-F22 transmission, upgraded hardware OBX LSD, $500 shipped
-Competition Clutch twindisk clutch SOLD
-Drive shaft Shop Stage 3.9 axles SOLD
-explicitspeedperformance H22 in DA mounts $ 275 shipped
-New AEM Engine Position Module $200 shipped
-Chassis & Suspension:
Custom Ground Control coilovers with Koni yellow adjustable shocks
Full Energy Suspension bushing kit including the trailing arms, Place Racing
cross member, 6 point roll cage, all around deadening material has been removed.
factory red paint with color matched moldings, JDM 90-91 Integra tail lights,
Clear front corner and bumper lenses, Custom 12lb single layer carbon fiber lift
off race hood with Dzus fasteners. Comes set up for H22 swap, will provide necessary items to convert back to a B series. $1100 obo picked up or shipped at your expense
Wheels & brakes:
-Konig Heliums 15x7 black 12lbs with Azenis 205/50-15 tires for the street SOLD
-New 15x8 spinwerkes with 26x9 toyo slicks with only 2 1/8th mile passes on them SOLD
-RCI drivers side 5 point harness $80
-Corbeau passenger side 4 point harness, $75
-Corbeau red Forza seats $250 each
PM me or email for quicker response at charles@topendusa.com
-greddy 46mm wastegate $400 shipped
Safety:
Head & valve train:
Block:
Intake system:
Turbo system:
Fuel system:
-STR fuel rail SOLD
Engine Management:
-MSD Digital 6 SOLD
Cooling system:
Wheels & brakes:
F.S
Precision Air to water 1000HP intercooler $500 obo
Meziere Water Pump $150
GO-AUTOWORKS Custom Ice box. $350 obo
This box will fit behind the stock 96-00 Civic bumper. It clears the 24.5 tire w/ plenty of room to spare, a 26" should b eno issue wither. The inlet also clears the stock headlight.
I'd Love to sell the Box, Intercooler and Pump together,( $900 all together) but wil seperate if needed. All parts have maybe 1/2 mile street time and 10 dyno passes. The turbo has not been used since the rebuild a few months ago, it is fresh, in the bag and ready to go.
Intercooler will come w/ the fittings and hoses.
Water pump will come w/ bracket
Ice box brackets are welded to the box to bolt up to the frame.
Catchcan comes w/ can and filters, no lines
[/[/QUOTE]
[/[/QUOTE]
LS OBD1
***Will Sell Distributors seperate for $130 shipped each.***
Del Sol Dual Core Radiator w/slim fan $100 shipped
Full Racing Suit $250 shipped
Shroud Pants - SFI Cert 3-2A/5 - Large
Shroud Jacket - Double lined SFI Cert 3-2A/5 - Large
Simpson Shoes - Size 12
Shroud Gloves - SFI Spec 3.3/1 - Medium
Shroud Neck Brace - SFI Spec 3.3
Paypal address is SupraTT_T78@hotmail.com
Jason
801-879-4940.
I do have texting so. Text me if ya got questions.
Jason
801-879-4940.
We recently moved to our new shop and uncovered alot of parts from our old location. Here is the list of parts so far:
AEM 3.5 bar map sensor, part number: 30-2130-50. Brand new, never used. 110.00.
ACL Race bearing sets. Main/Rod/Thrust bearing complete sets. 3 sets available for GSR, 3 sets available for B16a/LS. Brand new in the packaging. Standard size, not oversized. 115.00.
Brand new 1 quart catch can with drain. Has single -12 a.n inlet fitting. Great for high boost/high power turbo engines. 50.00.
AEM EMS 30-1052. Brand new in the box AEM EMS for 00-05' s2000s. 950.00.
AEM/Bosch style injector clips. Works with any obd-1 style injector both stock and aftermarket. 15.00.
AEM 0-2000 psi pressure transducer. Brand new, 2 available. Great for use with AEM EMS or Hondata for full throttle shifting. 110.00
GM 3 bar map sensor and pigtail harness. Brand new, 2 available. 50.00.
Iceman Civic Eg (92-95') headlight scoop kit. In like new condition, and not produced anymore this Iceman headlight scoop makes the best power hands down for b/d/h series engines on the street and at the track. I have personally seen 20 whp gains on the dyno, and 3-4 mph gains at the track with it. 275.00.
Not interested in trades of any kind. Any questions shoot me a PM or email to jeff@evans-tuning.com.
WIFE LOST HER JOB... REASONABLE OFFERS WILL BE ACCEPTED
Endyn Head Complete Springs Valves and Retainers $1000.00
Full Race Twin Manifold $1000.00
Precision Water To Air Intercooler $500.00
-Aeromotive A1000 - used, still in proper condition: 170$ shipped.
-MSD SCI-L Box, Great condition, Mounted inside car since purchase.
(Same box as a 6A-L, just Silver)
$135.00
-Add Blaster SS Coil
$35
Shipped
706-346-6024
I'm trying to build funds for the new transmission that's coming my way in a couple of months. I will not accept low ***** cause this would make a great spare tranny for me or another toy.
Option 1: This is a GSR transmission, with an LS final Drive currently. It also has a Quaife in it. If you buy the tranny I have a GSR FD for a small fee that can go with it if you wanted to get a GSR/type R Diff for it later. The synchronizers, factory hubs, and factory sliders and locking rings on the gears and shafts have been removed and replaced, by LIBERTY, with a Dog Engagement(Face Plating) system. This is by far the best investment I have ever made to my race car. Since the switch, missing a gear has been a thing of the past. It will engage the gear every time, no bullshit brass to wear out, or break. the center hubs are made from chromoly steel as well as the sliders. This is the best thing for any drag car where banging gears is a constant thing...whether its all motor or Forced induction. If you bust a gear, you find a replacement like normal, and then send it to liberty, they will modify it, and ship it back for $80. That's not bad at all and a great bang for the buck for someone that wants a consistent shift EVERY TIME. The 5th gear has been replaced with a billet aluminum hand cuff that braces the shafts together. I will include the GSR 5th gear. 1-2 gears are used street gears and 3-4 are brand new but all have only had 6 full hits at 2 events on them and NO Dyno Time. This can be ran on the street, it takes some getting used to and its kinda loud on engagement and you have to rev match to down shift on the street. Feel free to call with questions IF you are an interested buyer...and believe me I can tell the difference.
Price: $1750 Shipped
Option 2: You can buy the shafts with all of the gears and hardware on them(pictured below) and insert them right into your transmission (you can pick which countershaft you want (ls 4.2 or gsr 4.4) and that is that.
Price $900 - $1000 with Handcuff
If you buy the whole transmission, Arrangements can be made to meet at Mainstream Performance and I can fully disassemble and reassemble it for buyer/seller inspection.
706-346-6024
$135.00
$35
Shipped
706-346-6024
706-346-6024
These came out of my sleeved motor from GoAutoworks he said the pistons have low miles on them so the rings are reusable but replacements are pretty cheap 216shipped OBO. Help me finish my car someone needs them and there prices to move quick. Paypal is johnjr259@yahoo.com. The only trades I will entertain if for some suspension stuff
D16z6 SRP pistons only!!! 75.25 w/rings
Re: CRX Drag car with three K motors!
CRX with NHRA cert. Chromoly cage, M & B fiberglass front end, doors, hatch.
Three K24 motors, one is in the car with Hasport mounts.
Tons of brand new parts: 2 brand new SPEC clutchs, Gear Speed tranny with spool, fuel cell, never mounted Lexan, Axles, traction bar, radiator, more more more.
$4500
My loss your gain. Bring a trailer for the car, and a truck for all the parts. Also have stock doors, fenders, lights, wiring, etc. etc. etc.
http://s976.photobucket.com/albums/ae248/scottlucky/
714 34206485
$4500
714 34206485
i have a used aem ignition driver box that i got from dave fry a couple of years ago, and never used. its been sitting the basement collecting dust..lol
heres a pic from aem's website
asking $180 + shipping
JG Engine Dynamics Intake Manifold D-Series $150
M&H Slicks 24.5x8.5x15 Decent Condition $200 plus shipping for pair
Technomagnesio 15x6.5 40mm ET Wheels Fair Condition $350 plus shipping
Skunk2 68mm Billet Throttle Body $125 plus shipping
Rywire OBD0-OBD2 Complete Engine Harness with Jumper $250 plus shipping
Apexi PowerFC with Commander for OBD2A Honda/Acura $400 shipped
DixielandImports Please
1. One Gallon Plastic Fuel Cell.
Brand new never used.
In perfect shape
50 Shipped.
2. Bosch 255lph external fuel pump with mallory fuel filter.
Used but in great shape.
50 Shipped for both.
Take advantage of this stuff im selling cheap.
In perfect shape
50 Shipped.
im parting out my Spfwd car due to finace issues coming up(a baby). just went 9.96@153 at englishtown with these parts. the car also made 750@34 pounds on a mustang dyno with this set-up. add 3% for paypal and buyer will pay shipping fees. have some pics of most of the things if not they will be posted in a couple days.
Golden eagle polished fuel rail $90
Magnafuel fuel pressure regualtor $150
Fluydine radiator and slim fan $275
Generic intake manifold gasket(gsr) $30
4 inch aluminum exhaust $450(perfer local pickup)
G-force transmission(hydro input shaft) $4400
G-force cable spline input shaft $350
Rear t-bracket (gsr) $50
integra shift linkage and skunk2 shifter $100
FS : 5 speed trans out of an ep3 civic (K20) with axels, shifter and shifter cables. Have pics if you want them 500 + shipping PM
Competition twin disc B series brand new in plastic level c with upgraded hub 900 plus shipping and paypal fees
Full blown fuel system with walbro pumps 92-00 civic only used for dyno session 300 plus shipping and paypal fees
AEM cam gear for SOHC's. All brand new. Several available in blue, red, clear. $100 each which is the cheapest you'll ever see.
Auto RSX intermediate shaft. $40
New Hasport B series shift linkage. $old
J-Series swap harness for EG/DC chassis. This harness is designed for use on an auto J32 motor using an auto 99-03 ecu with further wiring mods to be used on a manual 5/6 spd transmission.....so basically its for the most typical J swap configuration. Harness was purchased BRAND NEW from Honda then Rywire did the wiring modification. Never used, still in the box that Rywire shipped it back to me in. $600 OBO. Remember, this isn't some ratty *** junk yard harness!
Brand new JE/SRP 81mm flat top 9.2:1 pistons. Complete with rings/pins. Been sitting around shop for a while now. P/N 149217 $300
OEM fuel tank sumps. Choose your own AN sized bung (you weld and provide). 3 avaialble $50 each.
K20A2 transmission. RSX-S 6 spd. Known good, pulled in favor for 5 spd. $700 obo.
Brand new polished DC 4-1 header for D series. $225 obo.
Brand new 60mm Apex EL boost gauge. Black face with memory/warning/peak feature. Reads in bar. Missing power plug (can be purchased from Apex) but sensor/wiring is there. $125 obo.
Shoot me a PM if you have any questions. Email me at sales@firststatemotorsports.com or call 302-798-7000
Most forms of payment accepted. Thanks.
Bullseye 72r comp turbo. It has the 87mm turbine wheel and 1.25 exhaust housing. This is the cutdown wheel to the 72. Get the latest and greatest from bullseye.
The baddest **** bullseye has to offer to the sfwd/outlaw guys.
I have 2 one brand new and one used. The used one has 3 dyno passes on it.
$1550 for the brand new one shipped to your door and $1450 for the used one shipped to your door.
look i need to move this thing, it just sits in my trailer, and i need cash, little cisco will be here in less than 4 weeks.
94 civic coupe, old moroso civic, the car would make someone a great bracket car.
the main issue is the firwall was replaced with a sheet of steel.
the car does have a onepiece front end, steel cage, gutted interior, rear section cut out and replaced, wilwood masters for brakes and clutch, also has wilwood gas pedal
car went a best of 9.80, best 60 1.49, best mph 162. like i said the car is heavy.
all the aftermarket front suspension has been removed and stock stuff has been put in to roll around, the straight axle is still in it and will come with the car. also comes with a custom gas tank and motor mounts, skunk 2 shifter and modified linkage
can supply more pics to email,
price is 3000, will bring to you as far as jersey for FREE!!!! i need this gone.
* $300 (900 value) -85mm 14.7:1 CP (+7cc) Pistons - 5 pistons availble (2 new, 3 used)
* $1100 RLZ Ported GSR Race Head with:
---------Phantom Grip Rockers
---------Ferrea Valve Locks (Keepers)
---------Skunk 2 Springs and Retainers
* $150 -Skunk 2 Pro Series 2+ Intake Camshaft
* $150 - Bell M2 Helmet (SA2005)
* $700 -SMSP Header (paid $1000 for it a year ago)
