Dart vs sleeved block - Honda-Tech
View Poll Results: Block wars
Dart block 39 26.53%
Sleeved block b series 108 73.47%
Multiple Choice Poll. Voters: 147. You may not vote on this poll
Old 05-08-2010, 06:58 AM   #1
Default Dart vs sleeved block
How many guys prefer or run dart blocks? How many guys prefer sleeved blocks?
The pros and cons of both. Any dyno tests to see if one makes more power with the same parts.
BLK2DOOR is offline   Reply With Quote
Old 05-08-2010, 12:26 PM   #2
hondaracing84's Avatar
Default Re: Dart vs sleeved block
Dart blocks are just to expensive. There are so many good ls blocks that I can get a hold of for so very cheap that it will cost $1000+ less to sleeve it than get a Dart block. Plus, I cant remember where, but I read an article about a shop that got a Dart block and it still needed a bunch of machine work and there was a pin size hole in one of the sleeves. After I read that I decided never to buy one.
hondaracing84 is offline   Reply With Quote
Old 05-08-2010, 02:16 PM   #3
I.C.C.'s Avatar
Quote:
Endyne....
Dart blocks = no bueno...
I.C.C. is offline   Reply With Quote
Old 05-08-2010, 05:54 PM   #4
^^^ sounds about right. Ill never buy one.
Old 05-08-2010, 08:04 PM   #5
i thought endyne sold them, with all work done ready to go?
Delsolcrzy is offline   Reply With Quote
Old 05-09-2010, 02:21 AM   #6
95DC2GS-R's Avatar
No reason to buy a Darton when you can sleeve a stock block and have ~$1500 in it and have something just as good for a fraction of the cost.
95DC2GS-R is offline   Reply With Quote
Old 05-09-2010, 04:56 AM   #7
da_unknown's Avatar
golden eagle for me plz
da_unknown is offline   Reply With Quote
Old 05-09-2010, 06:06 AM   #8
something different
redzcstandardhatch's Avatar
i had a buddy who ran one. wasnt problematic, worked great.
if you know the stuff to take care of, the extra prep work isnt really any big deal.. they are strong strong strong..
redzcstandardhatch is offline   Reply With Quote
Old 05-09-2010, 06:08 AM   #9
95DC2GS-R's Avatar
Quote:
^werd
Old 05-09-2010, 07:18 AM   #10
90dxhmt's Avatar
The only con is the money for a Dart.If you can afford it then no question get one. Some here may say not to but consider who you are taking advice from and what interest they may have in it such as affiliation with a sleeving shop etc.
90dxhmt is offline   Reply With Quote
Old 05-09-2010, 08:46 AM   #11
c5R
c5R's Avatar
dart blocks are great for a high HP build extra webbing suporting the mains thick sleeves. A block designed to take the abuse that we intend to put it thru. Also when looking at the cost vs sleeving a oe block take into consideration the tall deck block that they offer and also look at the cost of having a deck extension put on a oe block and then the price dosent look so bad.
Also the people that complain about a block needing work done to it. Who cares it is a custom block and if you are building a engine the proper way what is a 200-300 extra in machine work to make it work corectly.
c5R is offline   Reply With Quote
Old 05-09-2010, 10:20 AM   #12
95DC2GS-R's Avatar
with the coin you have to drop on a Dart block it should already come out of the box working correctly...
just my $.02
Old 05-09-2010, 11:37 AM   #13
B18C1CYA's Avatar
I run a dart block after I had nothing put problems with a sleeved block wich was done by a well known company on here , I figured I dont what any problems with sleeves droping or shifting , The dart block also has better cooling passages than a oe block and the bigger webbing is great. It realy dosent take to much much work to the block , a good cleaning and measuring over , hone it only cost me about 250 in machine work.
B18C1CYA is offline   Reply With Quote
Old 05-09-2010, 11:53 AM   #14
Quote:
just my $.02
agreed
Old 05-09-2010, 01:09 PM   #15
A dart block wont make a car faster...why do u need it
hello1320 is offline   Reply With Quote
Old 05-09-2010, 03:59 PM   #16
boostek9's Avatar
i have not ran either yet, but based on the power and times that the fastest guys are running on sleeved blocks, why dump the money
most important part of keeping a motor together is the tune, so spend the money for a good tuner
boostek9 is offline   Reply With Quote
Old 05-09-2010, 04:14 PM   #17
jdm inc's Avatar
x2
jdm inc is offline   Reply With Quote
Old 05-09-2010, 07:12 PM   #18
c5R
c5R's Avatar
most of the really fast guys wont use a dart block because they are afraid to get 10-15k wraped up in a engine just to have the block they are using be outlawed the next year so they stick with what they know will be legal. The dart block was well thought over when it was produced. The only reason that it never cought on to be the thing to use is NOPI wouldnt allow you to use it. So it never took off.
Old 05-09-2010, 07:54 PM   #19
Well thats gay hope they dont enforce that law.
Old 05-09-2010, 07:57 PM   #20
Gorilla RE's Avatar
Quote:
Yeah, that's an intelligent comment ...
I have personally seen WAY to much human error by "big named" companies in sleeving blocks. There is NO comparison to a DART block IMHO. Now, I'm not saying that sleeving never works because it does. But the DART choice is an all around much better one
-J
Gorilla RE is offline   Reply With Quote
Old 05-10-2010, 12:21 PM   #21
tuhboek's Avatar
Golden Eagle FTW
tuhboek is offline   Reply With Quote
Old 05-12-2010, 09:19 AM   #22
reboosted's Avatar
i run erl supper deck 2 block
reboosted is offline   Reply With Quote
Old 05-14-2010, 09:54 AM   #23
eagles3's Avatar
Yeah, I may be biased, but the dart blocks aren't a bad choice if you have the extra change. But, I would run an ERL sleeved block over a Dart. I've seen both and my mind is set, not to mention, the fact that you can work more closely with an individual sleeving company as opposed to a big name.
eagles3 is offline   Reply With Quote
Old 05-14-2010, 11:02 AM   #24
SPOOLINmatt's Avatar
if dart blocks were only a couple of hundred $$ more than a sleeved block i would have to say i would use that. Nothing beats a sleeved block at this point.
SPOOLINmatt is offline   Reply With Quote
Old 05-15-2010, 09:18 AM   #25
DA 4 Lyfe's Avatar
Coming from someone that has a 83MM sleeved block, if your only trying to net a little over 500whp I don't see the need to sleeve unless you plan on running it at that power daily.
DA 4 Lyfe is offline   Reply With Quote
Road Race 2.2L B-Series 4piston All Motor / Naturally Aspirated 58 08-10-2016 04:20 PM
WTB: DART Block Muckman Want to Buy 10 12-24-2014 11:17 AM
dart block, is it worth it? Aquafina Tech / Misc 40 05-20-2007 04:54 PM
DART race block integraintegra Acura Integra 4 05-07-2005 10:27 PM
dart blocks? drunknbass Drag Racing 16 07-05-2003 08:13 PM
Tags
block, blocks, civic, dart, decking, ep3, good, hawaii, hoda, honda, rsx, sleeved, sleeves, tech, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
