custom wire harness?
#101
Re: custom wire harness?
Very true. When you think about it it all adds up.
Before I went with the M800+SDL I was trying all sorts of stupid ****. NepTune+NLR AMS+1000+Prologger+dash display.... it all added up and I was still on the crappy OEM ECU.
It's an investment for sure. It's also nice to know that I can pull the M800 and throw it in just about any other veichle out there as well. All it takes is a new harness.
Neptune+NLR AMS1000+Innovate etc...
I hope I have the spot cash to buy motec...
#102
maybe if there was more info on motec vs aem people would pick the better one...if u buy a motec m400 do u still need to buy the motec dash..? and what are the advantages of the m400 vs the aem series 2....inputs/outputs??
#107
www.aempower.com
www.motec.com.au
#109
BTW, Motec just released the new M84 entry level ecu. It's not capable of quite as much as the Hundred series, but does a ton more than most entry level ecus. At $2550 WITH lambda and logging, it's a hell of a deal!
http://www.motec.com.au/m84/m84overview/
#113
#114
How does this digram look. I have fuel pump and the rest of my stuff on a relay,im removing the whole car harness. Am i missing anything? This is for a 99 si, i couldnt find anything on the A plug that i need to keep, am i wrong?
#116
Honestly man, I guess if it works for you....but dayum! I would be pissed if that is the only diagram I had to work off of.
And rogueeg6, I hope you are running solid mounts. And even then I would still be weary.
#118
#120
i got tired of relays hanging around and figured i would simplify the wiring to save from running a bunch of power wires and ground wires. and i came up with this relay board. I know Ryan (Rywire) has used a few of these in cars. i use one in my car its a nice simple way to wire up a street or all out drag car.
#123
Haha..I did that on my laptop. I never said it was perfect.I dont have a program too do it like the other one since I don't do it for a living. Was for general idea only....
But seriously does nothing go too the A plug on a 99si?
#125
Is this made for B series?
So ignotion Problems u have with B series are no more and USe K20 ignotion?
Would love to see a "how-to"
How much did iT cost?
