cp piston wrist pin - Honda-Tech
cp piston wrist pin
Old 03-28-2010, 11:34 PM   #1
hondah2b21's Avatar
Default cp piston wrist pin
hi i was wondering whats the max power made on a standard cp piston wrist pin.
im building a fully built h22 but i forgot to upgrade the wrist pin. i would hate for that to be my down fall on my build.
if this question is in the wrong location i apologize.
hondah2b21 is offline   Reply With Quote
Old 03-29-2010, 05:51 AM   #2
Mikey3000's Avatar
Default Re: cp piston wrist pin
Nobody is going to have an answer that's worth a damn. Your best bet would be to call CP and ask what they're designed to handle.
Mikey3000 is offline   Reply With Quote
Old 03-29-2010, 08:01 AM   #3
hatch34's Avatar
a close friend of mine made 700whp on off the shelf CP pistons
hatch34 is offline   Reply With Quote
Old 03-29-2010, 08:35 AM   #4
narfdanarf's Avatar
when I called CP and asked them they said between 5 and 600, but there are people on this forum making 1000ish on stock wrist pins...I personally have the upgraded ones just for peace of mind.
narfdanarf is offline   Reply With Quote
Old 03-29-2010, 09:40 AM   #5
hondah2b21's Avatar
thanks guys.
my budget is on its final string so i think im just gonna run the standard wrist pin and get the car dialed in. then upgrade when my money back to par. gonna enjoy what i have for now. thanks again.
Old 11-25-2011, 03:33 PM   #6
HybridKOOP's Avatar
for those who have upgraded pins (primarily CP), did you have to hone out the small end of the rod and/or wristpin opening in the piston to add clearance? or did you just run the upgrade .180 wall pin in the standard piston and rod? Thanks!
Lou
HybridKOOP is offline   Reply With Quote
Old 11-25-2011, 03:40 PM   #7
gringotegra's Avatar
On all of our engines, we have them Pin fit at the machine shop. Wiesco/JE/CP all of em. You'd be surprised how off some of them are.
gringotegra is offline   Reply With Quote
Old 11-25-2011, 03:42 PM   #8
ashtons300zx's Avatar
Its usually just a thicker wall pin same outer diameter, inner diameter is smaller and the material is of course stronger. Why not just upgrade pins, its like 75 bucks more to upgrade wrist pins. I ran my standard pins to 650+whp without problems but im not chancing it with the new power goals of 800+, not much money for peace of mind.
ashtons300zx is offline   Reply With Quote
Old 11-25-2011, 03:57 PM   #9
cibao2ner's Avatar
yea you always need rods hone at machine shop...they come tight....
cibao2ner is offline   Reply With Quote
Old 11-25-2011, 05:03 PM   #10
HybridKOOP's Avatar
Thanks guys. I was told by some popular vendors on here to just slide them in and run them without pin fitting. Anyone have a spec of what kind of clearance they should have? I'm running CP Pistons with their 9210 upgraded pins. Same outer diameter etc, just a slightly smaller hole in the middle. Thanks.
Lou
Old 11-25-2011, 05:52 PM   #11
zakura R's Avatar
My h2b made last year on 9.1 comp cp piston with stock wrist pin that they came with 831hp at 33psi never had any problem with it I will said that u will have to worry when u start making over 900hp plus just my opinion
zakura R is offline   Reply With Quote
Old 11-25-2011, 07:43 PM   #12
carbon fiber coupe's Avatar
i'd just save up the extra 150 and get the upgraded wrist pins
It's just a little piece of mind
carbon fiber coupe is offline   Reply With Quote
Old 11-25-2011, 07:59 PM   #13
boostedeg6-1's Avatar
Quote:
Hey, I think I know that guy your talking about... Oh wait, that guy was me haha!
I made 700/500 on stock wrist pins revving to 10200-10400 and beat the living hell out of the car, never had any problems. Wrist pins and pistons themselves looked great after 5k miles. Spun a bearing so got a chance to check them!
boostedeg6-1 is offline   Reply With Quote
Old 11-27-2011, 06:13 PM   #14
H-T Basic Sponsor
KStuned's Avatar
The wrist pins will outlast the off-the-shelf CP pistons at that RPM and power level. You'll eventually finds cracks at the base of the skirt. The non-strut design just can't deal with the abuse. The off-the-shelf pistons will last about a full season though... but when you're ready for a piston that really can deal with the abuse, we have these:
The underside looks like this... it's just an iphone pic but if you look closely you'll see the cracks in the corners of the skirt. Our HD piston has a strutted skirt to keep the skirt from flexing, cracking and collapsing.
__________________
KS tuned... H&F series whisperers, and more
Check out our Youtube Channel: https://www.youtube.com/channel/UC06...21YD5xGUu_NvBQ
KStuned is offline   Reply With Quote
Old 11-27-2011, 06:28 PM   #15
JJsMotorsports's Avatar
Those are some strong looking pistons Reid!
JJsMotorsports is offline   Reply With Quote
Old 11-27-2011, 06:36 PM   #16
SPOOLINmatt's Avatar
doesnt really make sense to me why they wouldn't manufacture the shelf version like that. People will still destroy it, but from melting rather than collapse.
SPOOLINmatt is online now   Reply With Quote
Old 11-28-2011, 07:26 AM   #17
HybridKOOP's Avatar
Those pistons look sick. Much beefier.
For those who are wondering about pin fitting, I am sending my pistons, rods, and upgraded CP pins to my machine shop today. I'll let you know the results. I am thinking no change will be necessary as the upgraded pins slide smoothly (if not even looser) into the piston and through the rod than the shelf pins do.
Lou
Old 11-28-2011, 08:58 AM   #18
zakura R's Avatar
Reid are those piston the hd wiseco ??? One 10.1 comp ????
Old 12-01-2011, 08:55 AM   #19
HybridKOOP's Avatar
Lou
FWIW, and for future searches that bring this thread up... I DID need to pin fit the upgraded CP pins. CP's tech told me that the upgraded pin is more ductile and needs a little "flex" or "give" compared to the standard pin. He suggested .001 to .0012 clearance in the piston hole, and .001 in the small end of the rods bushing (which is what my machine shop did for me.)
Lou
Old 01-07-2012, 06:57 PM   #20
jsilva's Avatar
That must have been in the motor I bought from you but you never sent me right? The one you scammed me on. Man it either takes stupidity or ***** to come on here and still post about the parts that you scammed me on. Im still waiting for my $1500 refund and dont worry I wont forget about it either.
jsilva is offline   Reply With Quote
Old 01-08-2012, 02:19 AM   #21
SLIM NOTHING's Avatar
Quote:
Originally Posted by hondah2b21 View Post
thanks guys.
dude the upgraded wrist pins for 1000hp+ from ipgparts.com are only $99.
SLIM NOTHING is offline   Reply With Quote
Old 01-08-2012, 05:13 AM   #22
rudebwoy's Avatar
Quote:
you DO NOT!!!! need to machine anything to run upgraded Wrist pins. the inside diameter of the upgraded pin is smaller therefore a thicker side wall, outer diameter remains the same as the standard pin. as stated earlier... I can associate it like this say you are running 24.5 slicks on 15" rims, an uprgade would be to run 24.5" slicks on 13" rims would give you bigger side walls without increasing the diameter of the tires. hope this helps.
rudebwoy is offline   Reply With Quote
Old 01-08-2012, 08:35 AM   #23
MikeySpec's Avatar
I went 760ish whp(dynojet) at 30psi for about 20-25 hits(including track+street passes). Then we we went 33 psi at the track once it ripped the wristpin right our of the piston and kabaaaam'd everything. It was CP's 11.5:1 shelf piston.......that was a bad idea.
MikeySpec is offline   Reply With Quote
Old 01-08-2012, 09:16 AM   #24
MR.johnson's Avatar
This is why I'm running diamonds this year.
MR.johnson is offline   Reply With Quote
Stock vs Aftermarket K20 Wrist Pin Question for my F22 build ZCHondaCRX91 K Series 1 02-11-2015 02:02 PM
CP Pistons stock wrist pins number KGP1 Tech / Misc 2 10-23-2013 11:24 AM
I need a wrist pin from a b series cp piston asap! seanc520 Want to Buy 6 12-03-2012 08:45 PM
wrist pin help Rootie524 Tech / Misc 1 07-04-2011 02:26 PM
cp pistons? bamboosted Drag Racing 16 02-21-2010 05:26 PM
Tags
cp, h22, honda, hondatech, pin, pins, piston, pistons, s2000, stock, tech, upgraded, vs, wrist, wristpin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
