S2000 AEM V2 Rev Limit Problem
Old 08-06-2011, 02:51 PM
fmfkid250's Avatar
Default S2000 AEM V2 Rev Limit Problem
I cant get my car to come out of the hole for anything.
With Antilag off and 2 Step off if I sit there and just floor my car to hit the rev limiter it will goto like 7800 then drop back to 7000.
If i am like 50% throttle it will go straight to 9000.
Am I missing a setting in V2 somewhere?
Thanks in Advance
Old 08-06-2011, 05:50 PM
3minburnout's Avatar
Default Re: S2000 AEM V2 Rev Limit Problem
Hope you get it figured out.
Old 08-07-2011, 01:16 PM
RealStreet's Avatar
Can you send me the cal and I'll look it over?
Jay@realstreetperformance.com
Old 08-08-2011, 09:50 AM
sc_at_QuaifeUS's Avatar
Is VSS accurate / functioning? Sounds like it's hung up on a limiter somehow, I'd look at TPS and VSS thresholds for the 2 and 3 step limiters.
Old 08-09-2011, 04:00 AM
jdm_ef9's Avatar
Get it straightened out?
Hit me up if you want me to take a look...
Old 08-09-2011, 05:07 AM
fmfkid250's Avatar
I gotta get some oa cool air to that turbo and hit the dyno again.
The next Day as the track acually had to pull fuel out for anti lag to work. maybe it was just spraying fuel so bad it would run. I thing I would see it coming out of the hood though.
Either way I will have an update after i cut a hole or remove a headlight.
b16hybridsol
Engine Management and Tuning
08-16-2012 09:11 AM
HondaKyle
18
09-08-2009 06:53 AM
Jeremy D. Swain
07-28-2005 01:31 PM
zerogt86
10-31-2004 05:57 PM
DeDonDeRosa
09-11-2002 10:18 PM
Quick Reply: S2000 AEM V2 Rev Limit Problem
