C16 vs. Q16 vs. VP Import? - Page 2 - Honda-Tech
Old 08-30-2009, 07:44 PM   #26
Default Re: C16 vs. Q16 vs. VP Import?
Quote:
Originally Posted by miller View Post
My egt's are pinned at 1745 (max on the racepak sensors) as soon as I click into 3rd gear. I am still being a little girl with the timing. That is part of it but I scared to go too fast. lol
Agree.... I think q16 burns a lot hotter in the pipe...... but the plugs dont show much heat.... You better not be scared in october 50 degree evening qualifiers, if you dont run better than you have been, gonna be disapointed.....
littlebluecrx is offline   Reply With Quote
Old 08-30-2009, 07:59 PM   #27
Quote:
lol, i surely wont disappoint.
miller is offline   Reply With Quote
Old 08-31-2009, 09:50 AM   #28
YZFR6's Avatar
So it is corrosive? What's the maintanance like? I noticed that it burns a lot more fuel as well. Wanted to know because I haven't used C16 and was on Torco's 118 last year. I did notice a difference in power this year with the Q16.
YZFR6 is offline   Reply With Quote
Old 08-31-2009, 11:18 AM   #29
twkdCD595's Avatar
Quote:
Originally Posted by SPOOLINmatt View Post
lol,i like my 9$ a gallon sunoco 110 ive been running for 2 years with Plenty of power.
I been sticking with my 7$ a gallon 112 Sunoco.
Buddy of mine runs q16 in his evo... loves it and made more power on it than c16 on kill. The only downside he saw was you have to run it through pretty quick and not let it sit a whole lot like everyone else is saying here. Price was same as if he ran C16 basically so why not make more with the oxygenated fuel.
twkdCD595 is offline   Reply With Quote
Old 08-31-2009, 12:09 PM   #30
Ls_dx's Avatar
Yeah , I run my under 6.00/gallon sunoco 112, mixed with some 91... for my junk.
Ls_dx is offline   Reply With Quote
Old 11-02-2009, 08:32 PM   #31
what is the target a/f for e85?
eg:R is offline   Reply With Quote
Old 11-02-2009, 09:18 PM   #32
bads2k's Avatar
so with id1000's or id2000's should we stick to c16 or is there a better fuel to use then c that we can use with those injectors without worrying about the corrosion that the q has
bads2k is offline   Reply With Quote
Old 11-02-2009, 10:00 PM   #33
Bugermass's Avatar
We run Q in the RSX, AFRs are 12.8s.. I'd go leaner and see if it picks up power but we still have 25 more PSI to go and were already breakin the 26inchers loose in 3rd @ 30PSI.
Bugermass is offline   Reply With Quote
Old 11-02-2009, 10:08 PM   #34
jdm inc's Avatar
Quote:
Quote:
Originally Posted by tony1 View Post
Q16 and VP Import causes the valve to swell, restricting flow. They car compatible with every other fuel we've tested to date. If they are run on either of those fuels, they come back to normal after airing out for about 48 hours.
We recommend C16 or C23 for really high hp applications.
jdm inc is online now   Reply With Quote
Old 11-02-2009, 11:20 PM   #35
tepid1's Avatar
Let's be clear if you are going to quote something....
That ONLY applies to the ID2000's
NOT the ID1000's
I run 8x ID1000cc's in my car on Q16 and have not had a single problem. The car hasn't seen full power yet, but it will soon.... that shouldn't matter though.
I don't know if the Bosch pumps like it though.... I guess only time will tell.
tepid1 is offline   Reply With Quote
Old 11-03-2009, 01:13 AM   #36
jdm inc's Avatar
yea i forgot to put that. it only applies to the id 2k
Old 11-03-2009, 08:15 AM   #37
B18c1turboedEK's Avatar
What happens if you mix c16 with q16? but you where tuned on straight q16?
B18c1turboedEK is offline   Reply With Quote
Old 11-03-2009, 09:56 AM   #38
locash's Avatar
Dont mix fuels, if you change fuel, retune. Simple as that..
locash is offline   Reply With Quote
Old 11-03-2009, 10:53 AM   #39
bads2k's Avatar
i don't even know if i can get c23 around here. How much is it for a 5gall container?
Old 11-03-2009, 11:05 AM   #40
Quote:
Damm i guess that was what was making my car miss really bad on Sunday... Guess ill drain it all out now...
Old 11-03-2009, 11:33 AM   #41
If you are going from q16 the only way to go is up and that is to import. That is if you are willing to spend the $25 a gallon for the import fuel.
In going from the q16 down to c23 you will gain some octane rating but you are losing the important part and that is the fuel being oxygenated. That helps in keeping detonation down. The fuel being oxygenated helps in the atomization/vaporization of the fuel.
Old 11-03-2009, 11:43 AM   #42
vtekthis's Avatar
agreed, but then again, a fuel with a oxegenate in it, in reality is a octane booster, which in theory raises the octane to, in lab terms 125-126 octane, so i guesss ur not neccessarily stepping down to 116 octane lol
vtekthis is offline   Reply With Quote
Old 11-03-2009, 12:08 PM   #43
Quote:
I see what you are saying but SG (specific gravity) has a major play in alot of how well a fuel does also. I would probably most likely go with the c16 over the c23 seeing as how both are non-oxygenated fuels but the SG of the c16 is .73x and the c23 is .70x. That is a huge difference in itself. That is most likely the major reason as to why c16 was such a succesful blend before the q16 came along.
Old 11-03-2009, 12:34 PM   #44
GT30EK's Avatar
Where is everybody getting there Q16? I live in NY so they dont sell it here. I call like three places in NJ, and they all said they were sold out and it would take 3 months to get. This was in the summer, thats why I still run c16.
GT30EK is offline   Reply With Quote
Old 11-03-2009, 12:39 PM   #45
vtekthis's Avatar
they lifted the rule about 3 weeks ago for the sale of MTBE fuel in NY, i know SK speed has it in stock, and im sure any other VP dealer should be able to get it aswell
Old 11-03-2009, 12:54 PM   #46
Darren(gt30ek), I have it in stock but not in 5 gallon pails. I jsut recieved 2 55 gallon drums late last week.
Old 11-03-2009, 12:56 PM   #47
tony1's Avatar
What affect does SG have on performance?
tony1 is offline   Reply With Quote
Old 11-03-2009, 01:11 PM   #48
Are you ****ing with me or do you want to see if I know the answer? Either way. Here is my answer to your question.
Fuels that have a higher specific gravity number have a higher resistance to detonation.
Import has a sg of .744 and is oxygenated, q16 has a sg of .716 an is oxygenated. C16 is not oxygenated and has an sg of .735. Now c23 is not oxygenated and has an sg of .713. C23 is the lightest of the group in question and is also not oxygenated. I am in no way saying that c23 is a bad fuel but why would you choose c23 over c16? Based solely on the octane rating?
The reason for this is that the fuel will i guess you could say "fall" faster, the faster the fuel falls the quicker the fuel gets away from largest concentration of heat which is the the top of the cylinder or other wise known as the combustion chamber.
In turn cold is denser than hot air so it falls where hot air rises.
Old 11-03-2009, 01:17 PM   #49
tony1's Avatar
I'm not f*cking with you. I have never seen a correlation between SG and resistance to detonation. I thought octane rating was a fuels resistance to detonation?
What about C10? It's SG is .763 and octane rating is only 104.
There's more to choosing a fuel than octane, but i've never heard SG being one of them unless you're trying to maximize fuel flow through a given injector/carb jet.
Old 11-03-2009, 01:25 PM   #50
GT30EK's Avatar
Good to know miller, I'll just bring my jug over. Looking to make some small changes this winter.
Fuel choices PSI GUY All Motor / Naturally Aspirated 6 09-13-2015 07:13 AM
Q16/VP import and id2000s hello1320 Drag Racing 87 02-19-2012 03:24 PM
Vp q16. Will_H Drag Racing 44 04-25-2009 10:33 PM
Anyone used VP Import fuel/race gas? boostedK20a2 Forced Induction 14 07-20-2007 08:24 PM
VP import fuel Vs C16 Fuel GDM S2K Drag Racing 39 05-26-2006 07:59 AM
Tags
c16, contact, corrisive, dyno, gas, honda, import, island, long, mix, q16, racing, sunoco, test, vp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
