BADDEST 99 GOES 10.14@133
block:
k24a4 sleeved bored and honed to 90.5
grp rods(4piston spec)
wiseco piston 15.5:1(4piston spec)
cometic gasket
oem accord crank micropolished
acl race bearings
new ported oil pump by me
new 2012 si chain and tensioner
head:
4piston 163c head
4 Piston PSI Pro Stock
4piston custom valves
kelford tool steel 179-c with outter lobes machined off
accord exhaust rockers(modified by me)
induction:
xcessive pro 58mm runner
modified plenum with accufab 90mm tb
vstack plate
5-4 inch intake pipe with 5inch vstack
transmission:
frana 4 speed
clutch masters fx600 twin
type-s axles
karcepts hubs
oem 4.7 final drive
wheels and tires:
bogart rt4 welded 13x9
mt 24.5x9
Heres some footage thanks to Tim aka eracer. make sure u check out his eastcoast coverage.
record pass
cometic gasket
acl race bearings
head:
4piston 163c head
induction:
vstack plate
transmission:
frana 4 speed
type-s axles
karcepts hubs
oem 4.7 final drive
wheels and tires:
mt 24.5x9
record pass
Re: BADDEST 99 GOES 10.14@133
Love the 99's putting in work. Great to see this car getting quicker.
So who is going to be the first into the 9's once the air cools down?
It will go 9s on the intake manifold with a few minor changes I think. 10.14 to 9.99 is more than a few hp though...its gonna take some effort.
Pretty sick *** eg coupe! Very impressive on a 99 and thanks for sharing the specs. Any info on the other L.B. tuned eg coupe?
