10sec h22 allmotor input needed!!!
Old 05-21-2012, 05:08 AM
justnprsh07's Avatar
Default 10sec h22 allmotor input needed!!!
10sec Allmotor h22 need input!!
What exhaust manifolds are the best out there and what heads are the best for the money to run? Looking for over 300hp block is complete with BMe rods, 4pistons 14.5-15:1 raised pin pistons 95/90.... Already have pro3s and what's your input on golden eagle intake manifold with 90mm acufab?
Also if anyone has a used head that will work for what I need, I'm PayPal ready for a good deal
Old 05-21-2012, 05:10 AM
Default Re: 10sec h22 allmotor input needed!!!
Also running b16 hydro with a spool.... What are u guys doing for gear setups
Old 05-21-2012, 05:20 AM
blade0314's Avatar
Check my build thread very similair to yours, also check out my Nah2b drag header thread, randy Owens makes the best drag h header and custom intakes in my opinion. Lastly rlz does the best head work
Old 05-21-2012, 05:21 AM
blade0314's Avatar
Btw i'm running hydro b16 with quaife LSD, but going to have the gears faceplated next season
Old 05-21-2012, 05:24 AM
JayWest's Avatar
Well there really arent too many 10sec n/a H's out there
But definitely look into Randy Owens headers' and one of his intake manifolds. Or a set of kinsler itb's and a nice box
RLZ or 4Piston for headwork
Old 05-21-2012, 05:34 AM
I messaged randy and waiting on a reply and may use golden eagle manifold and modify it since I already have it...
Old 05-21-2012, 05:38 AM
blade0314's Avatar
Drag header thread: http://Honda-tech.com/showthread.php?t=3032073
my all motor H2b build thread: http://Honda-tech.com/showthread.php?t=2998632
Randy Owens custom intakes and header thread: http://Honda-tech.com/showthread.php?t=2874447
Old 05-21-2012, 06:37 AM
Thanks for the links
Old 05-21-2012, 07:43 AM
4piston's Avatar
Displacement, airflow, compression...the H22 will make big power just like the Ks and you should be able to run 10s easily.
Old 05-21-2012, 07:51 AM
2k.civic.si's Avatar
one other suggestion is to get rid of the pro3 cams...go custom
Old 05-21-2012, 08:07 AM
JayWest's Avatar
it can be done and has been done on pro 3's
Old 05-21-2012, 08:09 AM
doesn't make it a good cam choice.
Old 05-21-2012, 08:10 AM
blade0314's Avatar
Pro 3s are you're best bet for proven power, custom cams are all experimental
Old 05-21-2012, 08:14 AM
^^^ x2 for my setup I havnt seen any thing faster... I'm sure there is a set out there somewhere that will do a little better but I'm not trying to be a record breaker or anything and close to 3k for a cam setup is a little much for what I'm doing here. Down here allmotor cars barely get into the 11s
Old 05-21-2012, 08:16 AM
Well point me in the right direction... I don't like spending money 3diff times to accomplish one goal. If you see anything in my setup that's not gonna cutt it please lmk. What do u guys recomend for a header? Apparently it's hard to get one made
Old 05-21-2012, 08:19 AM
If someone had a set that's been proven and has graphs to prove it I would be interested in them but other than that I'll stay with what I know works... Correct me if I'm wrong but I do believe randy was running pro3s?? But I can't see me spending all that money on a roller rocker setup "just yet"...
Old 05-21-2012, 08:21 AM
blade0314's Avatar
I'm telling you bro randy Owens hands down makes the best header, I'll text him and tell him to pm you when he gets a chance but I kno right now he's extremely busy with his business, give him some time
Old 05-21-2012, 08:48 AM
I deff would like to have one of his headers... What they run?
Old 05-21-2012, 08:52 AM
blade0314's Avatar
Not too sure about pricing but itll be worth every penny
Old 05-21-2012, 09:08 AM
hello1320's Avatar
ASP
Old 05-21-2012, 09:11 AM
JayWest's Avatar
last I talked to Stephen, he hadnt done any H series headers yet, not sure if thats changed in the last few months
theres also Jack Myers Manifolds
Old 05-21-2012, 10:05 AM
200 HP's Avatar
Saul @ Mission Critical Performance is a cylinder head master. Several of the top racers in the All Motor category will confirm this.
Email him: Saul@MissionCriticalPerformance.com
Old 05-21-2012, 10:27 AM
Originally Posted by hello1320
ASP
link or number I can call??
whom is this and how are they??
I sent a email...
Old 05-21-2012, 11:24 AM
SO.GA_SI's Avatar
Any body test these yet
http://www.xcessivemanufacturing.com...step=4&pid=234
Old 05-21-2012, 11:41 AM
Nice price...^^^
Quick Reply: 10sec h22 allmotor input needed!!!
