1985 Porsche 911 Carrera Gets restored by Tru Shine Detailing of Knoxville TN
Hey Everyone,
This was a restoration type detail that I was excited to get my hands on. I am such a big fan of these old school Porsche's and when this owner called me to come out and look at it, I was right on it. Once I inspected the car I knew right away the potential that it had. We scheduled the car and two weeks later I arrived.
This write up documents the process and products used to revive this 1985 911 Carrera. Lets get this going.
Here is the car when I arrived
Lets start with the wheels. One of my favorite wheel cleaners is P21s wheel gel. It is a pH balanced wheel cleaner safe and any wheels, painted,polished,clear coated... any wheel.
And another Favorite for cleaning the wheels is the EZ Detail Brush and Wheel woolies.
After the wheels I pre-rinse the paint to knock off any heavy and loose debris
After the pre-rinse, I then give the car a foam bath. The foam bath is very functional, and not just for show. When the foam is applied to the surface it acts as a suspension for the dirt and also gives the surface lubricity. all of this helps keep your car swirl free.
After washing the car, I brought it inside to inspect the paint under good lighting. this shows the tru surface and lets me know what I'm dealing with.
here are some pics under halogen lights which imitates what you would see under direct sunlight. the paint was very swirled and oxidized.
21 years of crust and residue build up around the emblems
So I finally got to work on the paint and begin the revival.
here is a picture of how much oxidation was removed.
Here is a before of the passenger door handle.
And here is the after
Rear Quarter Panel Before
Rear Quarter Panel After
For this next part, I noticed the emblem had 20+ years of crud built up around it, so I decided to remove the emblem to clean it underneath.
While making my way around the car, I found myself at this faded whale tail wing in the back. I knew that I could bring it back, so I taped off the surrounding areas and began to revive the paint
I also decided to paint the faded back air vents
here is a 50/50
and here was the final outcome
Here is another before and after of the Driver Quarter
On this door, not only did I polish out the scratches, I touched up the chips on the edge too.
These pictures are up close of what actually happens in Tru paint correction. The clear coat is leveled out removing the defects and not hiding them with glazes and waxes
Now for all the faded trim and plastics, I used a product that is a nano crystalized coating that has 1-2 years of protection for the rubber,plastic trim pieces, Gtechniques C4.
After all of that was done, I decided to revive the wheels by polishing them out and coating them with Poorboys wheel sealant.
Now that the car was finished, lets see what it looks like outside and in the sun.
Thanks for looking, For more write ups and articles, follow me on Facebook,Twitter, and Youtube.
Re: 1985 Porsche 911 Carrera Gets restored by Tru Shine Detailing of Knoxville TN
Amazing work, I always look forward to your threads, I have learned so much from reading them. A few questions though,
1. how did you remove and reapply the emblem on the back?
2. how did you paint the vents on the tailgate?
Great restorative detail, corrected all original paint is so much better than new paint in my opinion...
Great turn around! Original single stage paint you were working with right? How did the interior look on that car?
So, the 'key' to a premium shine is in the polishing of the paint to correct the imperfections.
Consumer Report found none of the 19 wax products tested were good enough to be Rated excellent, with most showing signs of deterioration within a few weeks.
They also noted: Thanks to today's clear-coat finishes, our testing shows that even the best wax will probably not improve the shine on a new car. Regular washing is still the most important step to protecting your car's finish. But a coat of wax can add a layer of protection against tree sap, bird droppings, and other contaminants--at least for a while.
http://www.consumerreports.org/cro/c...ying-guide.htm
So, I guess I won't be spending $80.00 on an 8 oz jar of Zymol car wax.
i hate to ask and you, and you can answer in PM if you want, but how much would I be looking to spend to do the same treatment, albeit my 20 year old honda.
I'd rather save the paint than repaint.
GDD's Resident Derp
You know your stuff. I want to take any car I love very much to you
Tru_Shine
Detailing
13
12-04-2011 07:51 PM
VelocityR
04-08-2004 10:59 PM
