painted door panels? how to strip the paint off - Honda-Tech
Old 04-19-2012, 08:33 AM   #1
jlbarrios's Avatar
Icon2 painted door panels? how to strip the paint off
Just picked up civic with light grey interior but they spray painted the door panels black wondering if anyone can tell me how to take the black paint off without messing up the grey color under it. Any advice will help ?
jlbarrios is offline   Reply With Quote
Old 04-19-2012, 08:26 PM   #2
Default Re: painted door panels? how to strip the paint off
Depends on what they used to paint the interior. For some stuff, rubbing alcohol and simple green might work and will cause minimal damage.
joeshmo is offline   Reply With Quote
Old 04-22-2012, 11:49 PM   #3
MidasGuy's Avatar
i would just get new door panels not worth stripping .
MidasGuy is offline   Reply With Quote
Old 04-23-2012, 10:23 AM   #4
jlbarrios's Avatar
Yea I think they just used regular spray can gloss black
But ill try it out thank
Old 04-23-2012, 11:11 PM   #5
Precision Hatch's Avatar
You can also use a hot water mixed with castrol superclean or believe it or not hand cleaner such as go Jo....I had a friend with a similar issue and I used a mix of those..(mix to strengh needed due to paint build up) and just used a simple green soap sponge from the typical dollar store the green side of course and those paticular sponges once wet don't scratch as much as your gonna need somthing with a small abrasive to it to help break down the coats.....since I'm sure its more than one coat ..but use this only to break the surface or the top coating off then switch to more of just the hot water .....HONESTLY!! in my opinion find a cheap part out on craigslist and you gonna find its much easier and cleaner on that approach buddy!!
Precision Hatch is offline   Reply With Quote
Old 05-03-2012, 09:22 AM   #6
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
Non synthetic brake fluid is mild enough to take the paint off but leave underneath ok.
I would hit up the junk yards for the easiest fix!
speedjunkie_g35 is offline   Reply With Quote
Old 05-09-2012, 08:54 AM   #7
get new door panels i hate when we have to fix previous owners **** ups! smh
rsongt3's is offline   Reply With Quote
Old 06-13-2012, 10:16 PM   #8
Is it plastic drip( or something like that?) , just try to use rubbing alcohol on some less visible place and see whats going on there
Tekkno is offline   Reply With Quote
FS 92-95 black interior eg hatch/coupe part out, also other color interior nasteboyii For Sale 9 07-31-2010 12:52 PM
WTB: DB8R/Grey DB8 door panels Maui Built Northern California (Sales) 3 02-21-2009 03:53 PM
**DIY** Dupicolor Interior dye how-to and review. 93eg2james Honda Civic / Del Sol (1992 - 2000) 35 11-25-2008 04:03 AM
How would you repair spray painted panels? infinitetruth Honda Civic / Del Sol (1992 - 2000) 11 06-24-2004 03:50 AM
How do i remove the sticky stuff in the door panel? 93FastLs Tech / Misc 9 04-29-2004 11:26 PM
Tags
2012, black, civic, crx, door, ep3, fit, grey, honda, interior, paint, painted, panel, panels, striping
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
